Tracks out of service
- ZachL
Re: Tracks out of service
David, you should probably move that post into its own thread. That sub is fairly known and large for a line that is out of service. That information could easily be buried in a month or so just from more posts accumulating in this thread.
I might do that later. Otherwise, this thread on another forum seems to be kept quite up to date with what's currently going on on the CSX Illinois Sub:ZachL wrote:David, you should probably move that post into its own thread. That sub is fairly known and large for a line that is out of service. That information could easily be buried in a month or so just from more posts accumulating in this thread.
https://indianarailroads.org/board/inde ... ic=19186.0
- NathanFromEngland
The signals replaced a 1990's CSX installation, but i do remain somewhat confused by the upgrade.freebrickproductions wrote:Continuing east, it's certainly odd seeing a rather modern CSX install abandoned in place like this, especially since this appears to have been installed around the time the line was closed:
https://www.google.com/maps/@38.6273959 ... 312!8i6656
https://www.google.com/maps/@38.6274025 ... 312!8i6656
That signal in turn replaced a mid-to-late 2000's CSX signal, here it is pictured in 2013.freebrickproductions wrote:Another crossing with a modern CSX signal and a 1990s CSX signal, with the latter retaining the original WCH mechanical bell!
https://www.google.com/maps/@38.5924779 ... 312!8i6656
https://www.google.com/maps/@38.5924896 ... 312!8i6656
Seems like this crossing may've still been recieving power.freebrickproductions wrote:Some more older B&O (maybe Chessie System) gated signals, with a rusty 1st gen WCH mechanical bell:
https://www.google.com/maps/@38.591794, ... 312!8i6656
https://www.google.com/maps/@38.5919648 ... 312!8i6656
I wonder why there is an early CSX DOT tag on the crossing?freebrickproductions wrote:Another early to mid 2000s install:
https://www.google.com/maps/@38.5965766 ... 312!8i6656
https://www.google.com/maps/@38.596531, ... 312!8i6656
Not sure why, but there is a counterweight next to the relay case, surely someone couldn't have found it in the nearby field and expected CSX to find a good use for it on another gate mechanism?freebrickproductions wrote:Now here's another waste of money. Prior to this line being closed, there were a pair of older signals here. However, after it was closed, one of the signals most likely got knocked down so of course CSX had to replace it!
https://www.google.com/maps/@38.60081,- ... 312!8i6656
https://www.google.com/maps/@38.6006669 ... 312!8i6656
Seems like this crossing still was also receiving power soon after closure although it was taken around 6 months after CSX shut the line downfreebrickproductions wrote:Some more old B&O gated signals with newer lights and gate mechs, but what appears to be a WRRS mechanical bell!![]()
https://www.google.com/maps/@38.6089844 ... 312!8i6656
That signal was installed when CSX split that OOS second track."freebrickproductions"]Some gated signals, one of which was installed by CSX while the other appears to be from the B&O. All of the equipment on them is from CSX though:
https://www.google.com/maps/@38.6226096 ... 312!8i6656
https://www.google.com/maps/@38.6224888 ... 328!8i1664
That's actually an early to mid 2000s install. Also, a good few of the crossings along the line were still hooked-up to power by as late as 2017, so I wouldn't be surprised if at least a few had the power kept on to them as late as 2018.NathanFromEngland wrote:The signals replaced a 1990's CSX installation, but i do remain somewhat confused by the upgrade.freebrickproductions wrote:Continuing east, it's certainly odd seeing a rather modern CSX install abandoned in place like this, especially since this appears to have been installed around the time the line was closed:
Does anybody know when installations of rubber grade crossing panels began and ended?
An online article stated that this track was pulled in 1945, but I say bullshit. Some of the crossing relics include rubber crossing panels, and current-style crossbucks. They aren't even in all that bad of shape considering their age. I say these installations are most likely 70's, but possibly early 80's
Carter St Marshall TX: https://www.google.com/maps/@32.5403942 ... bfov%3D100
Article about the line: https://tshaonline.org/handbook/online/articles/eqmpw
- brett nc railfanner
Greensboro, North Carolina:
https://www.google.com/maps/@36.0763456 ... 312!8i6656
https://www.google.com/maps/@36.0775244 ... 312!8i6656
https://www.google.com/maps/@36.0790666 ... 312!8i6656
https://www.google.com/maps/@36.080398, ... 312!8i6656
https://www.google.com/maps/@36.0836474 ... 312!8i6656
https://www.google.com/maps/@36.0802683 ... 312!8i6656
https://www.google.com/maps/@36.0835347 ... 312!8i6656
https://www.google.com/maps/@36.0847974 ... 312!8i6656
https://www.google.com/maps/@36.0852584 ... 312!8i6656
https://www.google.com/maps/@36.085658, ... 312!8i6656
https://www.google.com/maps/@36.0857815 ... 312!8i6656
https://www.google.com/maps/@36.0858713 ... 312!8i6656
https://www.google.com/maps/@36.0860785 ... 312!8i6656
A different spur in Greensboro:
https://www.google.com/maps/@36.0291848 ... 312!8i6656
Here's an abandoned line in Italy, all of these signals are now gone though.
Here's an old FS 64 install:
https://www.google.com/maps/@40.7710202 ... 312!8i6656
Several crossings, like this one, featured Teardrops and AL-70s:
https://www.google.com/maps/@40.7711822 ... 312!8i6656
https://www.google.com/maps/@40.7710495 ... 312!8i6656
https://www.google.com/maps/@40.7709909 ... 312!8i6656
Near as I can tell, aside from what remains of the ROW, this bridge, with some rails, contains the only remains of this line:
https://www.google.com/maps/@40.7711097 ... 312!8i6656
In much happier times:
https://www.google.com/maps/@40.7709813 ... 312!8i6656
https://www.google.com/maps/@40.7710662 ... 312!8i6656
A year prior:
https://www.google.com/maps/@40.7710754 ... 312!8i6656
https://www.google.com/maps/@40.7666442 ... 312!8i6656
Prior to the dismantling of the line:
https://www.google.com/maps/@40.7666783 ... 312!8i6656
A year prior:
Here are some tracks out of service:
Only because they're melted at this point.
- NathanFromEngland
If you could get a big stick and trace some tracks and carefully tracing some ties then maybe it would be better.ZachL wrote: Mon Apr 01, 2019 12:09 pm Here are some tracks out of service:
Only because they're melted at this point.![]()
But over here we don't really get that much snow, and we rely on car tracks instead
and yes ik its an april fools joke.
Found an out-of-service line at Baytown TX with a ton of mast signals. Start here: https://www.google.com/maps/@29.7176118 ... 12!8i6656 , and follow the line NW into Baytown where it connects with a main
