Probably their attempt to bring their name into the UK that didn't go dso wellNathanFromEngland wrote:I know ASDA is the British subsidary of Wal-Mart, but why include the Walmart name here? I've never seen it anywhere else.
https://www.google.com/maps/@53.4152296 ... 6656?hl=en
Google Street View
- ZachL
Re: Google Street View
"failed" traffic signals.
https://www.google.com/maps/@53.4709697 ... 384!8i8192
While browsing street view, i came across what appear to be Stanton and Stavely concrete street light poles with what appear to be very rare GEC Z8430CM lanterns from the 1960's/1970's.
https://www.google.com/maps/@53.4746351 ... 312!8i6656
The street lighting in this area and the region of Kirkby and Knowsley was replaced entirely in 2014, but seeing this on public property is a rare sight.
Still there as of 2017.
https://www.google.com/maps/@53.474582, ... 312!8i6656
Abandoned traffic signals.
https://www.google.com/maps/place/S+Boy ... -90.253203
Although the area has changed much since then, wonder why the old signals were never activated and just left to be damaged/flashing?
Just because a signal remains in a permanent flash cycle does not necessarily mean it's abandoned...NathanFromEngland wrote:Abandoned traffic signals.
A Durasig 12 inch pedestrian signal with either a damaged lense or a bright light that nearly hides the "DON'T WALK" lense.
https://www.google.com/maps/@38.5888507 ... 312!8i6656
The Durasig on the right is alarmingly dim, or it's the sun.
https://www.google.com/maps/@38.5832848 ... 312!8i6656
Another incandescent Durasig, slanted slightly most likely due to shifting in the mast clips holding the signal to the mast.
https://www.google.com/maps/@38.5822525 ... 312!8i6656
Neither. That's what happens when an incandescent bulb stays on for so long, it causes the plastic film to heat and melt, thus showing the whole range and not just the word outline.NathanFromEngland wrote:A Durasig 12 inch pedestrian signal with either a damaged lense or a bright light that nearly hides the "DON'T WALK" lense.
I seen it here too on this older streetview:NathanFromEngland wrote:What on earth are these things?
https://www.google.com/maps/@53.3986175 ... 6656?hl=en
https://www.google.com/maps/@53.4041472 ... 6656?hl=en
https://www.google.com/maps/@53.4063944 ... 6656?hl=en
Since then, the Walmart name was dropped from the sign.
https://www.google.com/maps/@52.2770464 ... 312!8i6656
And, if you're a Keeping Up Appearances fan, you might notice this on-site petrol station was used in one of the episodes.
https://www.google.com/maps/@52.2764705 ... 312!8i6656
This fella is asleep in an odd place.
https://www.google.com/maps/@56.9559293 ... 312!8i6656
Look's like someone had an accident here!
https://www.google.com/maps/@35.8935965 ... 312!8i6656
