DANGER ANOTHER TRAIN COMING Blankout Sign
Brian556
This is in an FDOT FB post. Unfortunately you cannot see the whole sign
Can anyone readily identify the crossing pictured?
https://www.facebook.com/RideSunRail/ph ... =3&theater
Re: DANGER ANOTHER TRAIN COMING Blankout Sign
Yep you can see the signs in GSV:
https://www.google.com/maps/@28.538362, ... 312!8i6656
Huh, the GS Type 2 on the one signal got replaced. Interesting.Brian556 wrote:Yep you can see the signs in GSV:
- NathanFromEngland
That would've been done by CSX back in the day.freebrickproductions wrote:Huh, the GS Type 2 on the one signal got replaced. Interesting.Brian556 wrote:Yep you can see the signs in GSV:
The real question is where on earth did this Safetran/RACO bell come from.
https://www.google.com/maps/@28.5403106 ... 000!8i5500
Re-used from another crossing, most likely.NathanFromEngland wrote:That would've been done by CSX back in the day.freebrickproductions wrote:Huh, the GS Type 2 on the one signal got replaced. Interesting.Brian556 wrote:Yep you can see the signs in GSV:
Wonder which one then. The bell replacement there was definitely the work of FDOT and not CSX.freebrickproductions wrote:Re-used from another crossing, most likely.NathanFromEngland wrote:That would've been done by CSX back in the day.freebrickproductions wrote:Huh, the GS Type 2 on the one signal got replaced. Interesting.Brian556 wrote:Yep you can see the signs in GSV:
- PlyingKibbles89
There's a lot of them on RTD in Colorado, except it says '2nd Train Coming'.
https://www.google.com/maps/@39.7364969 ... 6656?hl=en
Proud owner of too many things. | GE B40-8W's are the best. | CO, CA, NE, WY, NM, AZ, TX, FL, KS, IA, MA, CT, NH, ME, UT, MO, AL, TN, GA, MS, LA
My newest update: https://www.rxrsignals.com/Phpbb3/viewtopic.php?t=6965
