https://www.google.com/maps/@30.3162851 ... 384!8i8192
Ideally this railroad crossing should be replaced with a grade separation because it is right by a hospital, but can it be done? It seems like it would be difficult.
Would it be possible to grade separate this railroad crossing?
Megabox
Re: Would it be possible to grade separate this railroad crossing?
Yea, though you'd have to sink the freeway ramps (farther) and intersecting road in addition to the road for grade-separating the crossing in question.
Ideally it sounds good but fiscally not so muchMegabox wrote: Tue Jul 09, 2019 12:25 pm https://www.google.com/maps/@30.3162851 ... 384!8i8192
Why not just raise the tracks over the road?freebrickproductions wrote: Tue Jul 09, 2019 10:20 pm Yea, though you'd have to sink the freeway ramps (farther) and intersecting road in addition to the road for grade-separating the crossing in question.
Because you've got a drawbridge almost immediately to the north that would have to be rebuilt, and then I-95 crosses over the tracks almost immediately to the south, which would also have to be redone.Username1 wrote: Mon Jul 15, 2019 2:56 amWhy not just raise the tracks over the road?freebrickproductions wrote: Tue Jul 09, 2019 10:20 pm Yea, though you'd have to sink the freeway ramps (farther) and intersecting road in addition to the road for grade-separating the crossing in question.
FWIW, the hospital probably had the railroad tracks in mind when they were building/expanding on the property as well.
