CSX Dothan Sub (and related lines) Discussion
Re: CSX Dothan Sub (and related lines) Discussion
Chased both the BAYL and A724 today, and got a few things to report.
First off, in Dothan:
At Range Street #1, the Safetran bell is dead though the WCH mechanical bell there is dead. The crossing, along with Selma Street #1 and Alice Street, also did a tail-ring malfunction (though I didn't record the one at Selma Street).
Columbia Highway's MI bell is definitely dying, as it sounded rather bad while it struggled to ring. The WCH mechanical bell at Burdeshaw Street #1 and the MI mechanical bell at Newton Street are also both dead. Unfortunately, I think this spells the end for the remaining mechanical bells on the BAYL between their main yard in Dothan and CSX.
Secondly, from my chase of CSX A724:
Martin Luther Kind Jr. Drive in Bainbridge has a WCH mechanical bell that sounds like it's dying, though the other WCH mechanical bell there still sounds rather healthy.
The WCH mechanical bells at the Miller Avenue and Griffin Street Crossings all sound rather healthy, though, for some reason, the bells at Miller Avenue shut off while the gates are only halfway down.
Both bells at Brinson Airbase Road in Brinson, GA sound rather healthy, though both do begin to struggle a bit when the gates begin to lower.
Both WRRS mechanical bells at the Church Street crossing in Iron City, GA, work, though the one on the northbound signal is dying. The gate mech on that signal is also broken (appears that the counterweights are too heavy), with it failing to lower all the way, which causes the bell on it to stay on a little while longer (which probably ain't helping it).
Pot Likker Road in Jakin, GA, does indeed have a GS Type1/Type 2 combo, with the GS Type 1 being on the northbound signal. The other signal also had its lights replaced with WCH 12x24 inch lights with LEDs (Dialight LEDs for the front lights, WCH 2nd Gen LEDs for the rear lights), though one of the rear LEDs is dead.
And finally, both of the WCH mechanical bells at Glen Lawrence Road in Cowarts, AL, sound like they're on their way out, sadly.
Chased the CSX local based-out of Bainbridge and A724 today, got a few things to note:
The gate mech on the newer signal at Albany Road in Bainbridge takes forever to begin to rise, in fact, the other one is almost all the way up before the newer one begins to rise. Interestingly enough, this can be seen on street view as well:
https://www.google.com/maps/@30.9103265 ... 312!8i6656
The Safetran bell on the southbound signal at Wiley Avenue in Donalsonville is dead as well.
Finally, Jordan Avenue in Cowarts is all incandescent, nicely enough. The WRRS bell also works, though it rings rather slowly and a bit weakly, it seems.
- NathanFromEngland
Maybe bad relays? I've never seen bells shut off while the gates are lowering.freebrickproductions wrote: Tue Jul 30, 2019 10:49 pmThe WCH mechanical bells at the Miller Avenue and Griffin Street Crossings all sound rather healthy, though, for some reason, the bells at Miller Avenue shut off while the gates are only halfway down.
That or something could be drawing a lot of power if I had to guess.NathanFromEngland wrote: Fri Aug 02, 2019 3:23 amMaybe bad relays? I've never seen bells shut off while the gates are lowering.freebrickproductions wrote: Tue Jul 30, 2019 10:49 pmThe WCH mechanical bells at the Miller Avenue and Griffin Street Crossings all sound rather healthy, though, for some reason, the bells at Miller Avenue shut off while the gates are only halfway down.
I think the bells are likely set to shut off when the gates get to the point that gravity brings them the rest of the way down, rather than to when the gates are all the way down, for whatever reason.ZachL wrote: Fri Aug 02, 2019 8:30 amThat or something could be drawing a lot of power if I had to guess.NathanFromEngland wrote: Fri Aug 02, 2019 3:23 amMaybe bad relays? I've never seen bells shut off while the gates are lowering.freebrickproductions wrote: Tue Jul 30, 2019 10:49 pmThe WCH mechanical bells at the Miller Avenue and Griffin Street Crossings all sound rather healthy, though, for some reason, the bells at Miller Avenue shut off while the gates are only halfway down.
Only way to find out is to lift one of them, but you didn't hear that from me.freebrickproductions wrote: Fri Aug 02, 2019 10:30 amI think the bells are likely set to shut off when the gates get to the point that gravity brings them the rest of the way down, rather than to when the gates are all the way down, for whatever reason.ZachL wrote: Fri Aug 02, 2019 8:30 amThat or something could be drawing a lot of power if I had to guess.NathanFromEngland wrote: Fri Aug 02, 2019 3:23 amMaybe bad relays? I've never seen bells shut off while the gates are lowering.freebrickproductions wrote: Tue Jul 30, 2019 10:49 pmThe WCH mechanical bells at the Miller Avenue and Griffin Street Crossings all sound rather healthy, though, for some reason, the bells at Miller Avenue shut off while the gates are only halfway down.
Didn't really have anything too noteworthy yesterday, but I chased A724 and a grain train (G410) today, so I have a few things to note:
First off, the broken gate mech at Church Street in Iron City, GA, has been fixed.
Secondly, CR 1135 in Ansley, AL has a GS Type 1 e-bell.
Third, the Safetran Type 3 e-bell on the cantilever signal at Church Street in Troy, AL, is dead. The other one still works though.
And finally, the WRRS mechanical bell on the eastbound signal at Lee Street in Brundidge, AL, is dead. The other one still sounds quite healthy, though, other than slowing down when the gates start to lower.
Tomorrow, I make my trek back to Huntsville, and I'll be stopping in Montgomery to get a few crossings there documented, along with possibly trying to get at least one more train on the CSX S&NA South Sub on my way back up.
Didn't shoot the S&NA South Sub today, wound-up hanging around Montgomery all day prior to heading home. However, I was able to get an Autorack train on the northern end of the Dothan Sub, and it turns out that Fleming Road in Montgomery uses a GS Type 2 and a very quiet GS Type 1.
