7-28-19 Spooner Road malfunction, near Donalsonville, GA
Also, when I described these signals as being 80s CSX signals, turns out I was a bit wrong. It appears that these are (most likely late) Seaboard System signals (that would be from the 80s as well), given the fact that they feature double-sided bases, shorter masts, and an older-style relay case. 1980s CSX signals feature single-sided bases, taller masts, and relay bungalows, and can also be found on former Chessie System lines (while this style of signal can only be found on former Seaboard System lines).
