Tracks out of service
NathanFromEngland
Re: Tracks out of service
Post by NathanFromEngland »
freebrickproductions wrote: Tue Feb 25, 2020 1:10 am
MapsSurfer wrote: Mon Feb 24, 2020 11:05 pm
ZachL wrote: Mon Feb 24, 2020 9:47 pm Some news out of Sarasota. The SGLR has removed equipment and ripped up their trackage through Sarasota starting from Fruitville Road and points south.
That's very sad, seeing a railroad be ripped apart only to be replaced by a damn trail.
Do you think any of the equipment could be salvaged?
Some of the stuff did appear to be newer, and I've heard that the SGLR tends to be rather "thrifty" at times, so I'd imagine that they would keep the equipment and re-use what's still in good shape.
Pretty confident i covered the line a few months ago.
I have seen some signals that were salvaged and used, just the crossbucks were altered IIRC.
Wanna bet that the tracks on the line were "thrifty" as well? :LOL3:
luke
Post by luke »
Been a long time since I've posted on this forum.
Some out of service cantilevers at Morton, WA: https://www.google.com/maps/@46.5607688 ... 312!8i6656
This is near the end of an ex-Milwaukee road branch line now owned by Tacoma Rail. The line is not abandoned, but it has not been used since 2006 as of result of several washouts and a compromised bridge. The lumber mill to the right was the lone remaining customer.
NathanFromEngland
Found the remains of two out of service crossings on a spur in Leeds, England, the crossing surface hasn't been resurfaced over and the tracks have been lifted, i would assume that a train obviously hasn't been over here since probably the mid to late 1990's judging by the modern looking Schneider Electric building.
https://www.google.com/maps/@53.7833928 ... 384!8i8192
You can still see the ballast from where the tracks were, but i'm not sure when the tracks were lifted however.
https://www.google.com/maps/place/Aired ... -1.5454026
luke
Post by luke »
Partially intact signals on an out-of-service segment of the Stockton Terminal and Eastern RR east of Stockton, CA: https://www.google.com/maps/@38.0221329 ... 312!8i6656
Per some information on TrainOrders, this track was last used in the late 1980s.
brett nc railfanner
Post by brett nc railfanner »
NathanFromEngland
brett nc railfanner wrote: Thu Mar 12, 2020 12:55 am Nearly intact US&S signals:
https://www.google.com/maps/@38.1376605 ... 312!8i6656
Interestingly enough, they had US&S Teardrops mounted to the sides, but they were removed by 2012.
brett nc railfanner
Abandoned signals in Lillie, Louisiana:
https://www.google.com/maps/@32.923247, ... 312!8i6656
Doge_Illinois
Old signal remants
Post by Doge_Illinois »
Remains of a signal. There used to be a crossbuck on there, but it was removed between 2012-2015.
https://www.google.com/maps/@38.6793495 ... 56!5m1!1e1
KCMO Railfan
Post by KCMO Railfan »
Doge_Illinois wrote: Sat Apr 18, 2020 10:51 pm Remains of a signal. There used to be a crossbuck on there, but it was removed between 2012-2015.
Appears this crossing used to be protected with Wabco triangle gates. Wonder why every signal on this line got downgraded to crossbucks?
