Main Street (SC 261), Kingstree, SC
*originally recorded on 2-25-22*
Signal on the left: 3 pairs of Safetran 12x24 inch lights with Leotek EV Series LEDs, a General Signals Type 1 electronic bell, a Siemens gate mechanism, and NEG LED gate lights.
Signal on the far right: 2 pairs of Safetran 12x24 inch lights with Leotek EV Series LEDs, 1 pair of WRRS 8 inch lights, , a WRRS mechanical bell, a Safetran gate mechanism, RECO LED gate lights, and a RECO gate light.
Signal on the near right: 1 pair of Safetran 12x24 inch lights with Leotek EV Series LEDs, 1 pair of WCH 12x24 inch lights with Leotek EV Series LEDs, 3 pairs of WRRS 8 inch lights, a General Signals Type 2 electronic bell, a Safetran gate mechanism, and NEG LED gate lights.
On February 25th, I got on up and went on over to Kingstree to start my second day of railfanning on the A Line. Decided to start out at Main Street in Kingstree, and, after a little bit of waiting, I was able to get my first train of the day, and probably my favorite catch of the whole trip: CSX I038 with a YN2 Dash-9 leading a YN2 AC44CW! Been a long time since I'd seen one of these Dash-9s leading, much less in YN2, so it's great to see some still running around. Unfortunately, I wound-up restarting my camera just a few seconds before the crossing activated, but this video still came out pretty good anyways.
This crossing is a pretty nice one, featuring a trio of RACO cantilevers from the SCL and a rather excellent bell combo. It appears that the SCL originally installed these signals back in the 1960s, I believe with only two bells (though it's possible that the signal next to the Amtrak station also had one that was later removed at some point). In the early 90s, it appears that CSX replaced all of the lights on the left-hand cantilever with the current Safetran 12x24s (though they were incandescent at the time). Then, in the early 2000s, CSX added extensions for the two cantilevers facing Main Street and replaced the original WRRS and/or GRS gate mechs here with three Safetran ones. At the same time, it appears that the closer signal had its original cantilever-mounted WRRS bell replaced with a General Signals Type 2 e-bell mounted on the gate mast.
It appears that the crossing then remained largely unchanged until sometime around 2018 or 2019, when the closest signal had all of its WRRS 8 inch overhead lights replaced with a set of WCH 12x24 inch lights with LEDs, and the cantilever next to the station was upgraded to LED as well. At around this same time, the gate masts here were all replaced with new ones (the Main Street cantilevers getting ones about the same height as the extended ones and the cantilever for the side street getting a slightly taller one than previously), but all of the original WRRS bases were retained. As part of this upgrade, however, it appears that while CSX retained the bells and gate mechs on the right-hand cantilevers, the one next to the station got a new Siemens gate mech and a re-used GS Type 1 mounted on its gate mast. Finally, sometime between January and August of 2019, CSX replaced a few more lights here, these all being on the right-hand cantilevers. The one for the side street here had its overhead lights replaced with a set of re-used (but LED) Safetran 12x24 inch lights, and the closer cantilever also had half of the WCH 12x24s replaced with re-used Safetran 12x24 inch lights (with LEDs in them, of course) from the 1990s.
Since then, thankfully, it doesn't appear any major changes have occured to this crossing. The bells here all sound great together, so I'm glad I was able to record it. A full trio of RACO cantilevers like this doesn't seem to be too common these days either, especially in this part of the country, so I'm glad they're all still around. Hopefully these great signals remain unchanged for a good while yet, and I'm glad I was able to get this recorded.
