Make up a Dream Railroad Crossing(s)
Doge_Illinois
Re: Make up a Dream Railroad Crossing(s)
Post by Doge_Illinois »
Crossings #29 & #30 - Bergensville Road and Arlington Avenue, Darrenville, IL.
Crossing Owners - Amtrak
Dot Numbers - 917598C & 917602D
These crossings are soon to get new signals, there is conduit and a new relay case nearby.
Bergensville Road Signals:
-Safetran Bases
-2 pairs of Safetran 12x24" Lights each (Incandescent)
A GS Type 3 is on the relay case for this crossing.
Arlington Avenue Signals:
-Safetran Bases
-2 Pairs of Safetran 12x20" Lights (GE Uniform Look LEDs)
There is a WCH Mechanical bell on the relay case!
Crossing Update #5 - Terryson Street, Laramie, IL
Owned by NS.
On April 25, 2022, the cantilever with the WRRS Bell was destroyed in a train accident, thus it was replaced completely.
Then by May 10, 2022, the other WCH Cantilever got a LED Upgrade and the WCH bell and gate mast were replaced. The new info is below.
Signal #1, now updated:
Cantilever - Older Style WCH
Gate Mast - Siemens Base
Gate Mechanism - Siemens Imprinted
Gate Lights - RECO LED 4"
Lights - 4 Pairs of Safetran 12x20" (GE Uniform Look LEDs)
Bell - General Signals Type 3
Signal #2, now replaced
Cantilever - Siemens
The Perry Street signal and the Pedestrian signals are the same.
jff1999
Post by jff1999 »
A nature trail crosses a UP track and the only device protecting this crossing is an NEG E-Bell
Janntastic
Post by Janntastic »
It would be adding on rare parts to my existing crossing.
Signal #1
Base: Safetran.
Lights: Safetran.
Light size: 8-inch.
Light type: Incandescent.
Gate mechanism: WABCO triangular.
Bell: Safetran Hybrid bell.
Gate lights: Any.
Bell sequence: Full.
My :ROFL: copter goes soi soi soi soi soi soi soi soi soi
Owner of a crossing signal with Safetran 8 inch lights, a Safetran base, and a WCH mechanical bell (1st generation).
Doge_Illinois
Crossing #31:
Williamsburg Avenue #1, Keeves, CA
Owner: NS
Signal #1:
-WRRS Base
-1 Pair of WRRS 8" Lights, 1 Pair of WCH 8" Lights
-US&S Teardrop Bell (1st gen)!
Signal #2:
-WRRS Base
-2 Pairs of WRRS 8" Lights
Crossing #32:
Williamsburg Avenue #2, Keeves, CA (Abandoned)
Former Owner(s): Conrail/CSX
This line was closed in 1999 after Conrail went defunct, originally the line was going to be ran by CSX afterwards, but after they got the line owned, they did nothing to it, and they sold the line in 2005.
Signal #1 (downgraded):
-WCH Base
Signal #2 (downgraded also):
-WCH Base
The relay case has a mount for a bell on there, but there is no longer a bell on there.
Crossing Update #6:
Route 180 (Logansport Road), Simeon, IL.
Owners: UP & NS
The two NS signals have gotten an LED Upgrade, with the gated NS signal receiving a new gate mechanism.
Updated NS Signal info:
Signal #3:
-Safetran Base
-2 pairs of Safetran 12x20" Lights (GE Uniform Look LEDs)
Signal #4:
-Safetran Base
-GS Type 3 Electronic Bell
-Siemens Imprinted Gate Mechanism
-RECO LED Gate Lights
The UP side has no changes.
Doge_Illinois
Crossing Update:
Wolcott Street, Pine Tree, IL.
Sadly, CSX has since turned the line into a trail, thus removing the former signals.
This was the info from before, the signals however were seen in a yard over in Delene, IL.
Signal #1:
Base: WRRS
Gate Mechanism: WRRS
Gate Lights: WRRS Lantern!
Lights: 2 pairs of WRRS 8" Lights (Cast Iron!)
Bell: WRRS 1203 Mechanical Bell!
Bell Sequence: Full Activation
Crossbuck: Cats-eyed!
Signal #2:
Base: WRRS
Crossing:
13th Street, Delene, IL.
Owner: NS
Crossing Dot #: 923467F
Signal #1:
-WRRS Base
-WRRS Gate Mechanism
-Safetran 12x20" Lights (2 Pairs, Incandescent)
-GS Type 3
-NEG LED Gate Lights
Signal #2:
-WRRS Base
-Safetran Mechanical Bell (2nd Gen)
Signal #3 (for visibility reasons, there is a third signal):
-WRRS Base
-1 pair of WRRS 8" Lights
NSsignal
Post by NSsignal »
Street: Davis St
Company: Norfolk southern
Dot: N/A
1st signal
Base: Wabco
Gate Mech: Safetran model 85
Bell: WCH M-Bell
Gate striping: old
Gate lights: WCH 7 inch incandescents
Cantilever: Safetran 1970s RACO design (5 section) in front of gate
Lights: dialight ball LEDs with side lights
Frames: 12 by 20 inch WCH frames
Junction box: WCH
Crossbuck: thick font
No track sign
Cantilever has a STOP ON RED SIGNAL sign. (white letters on black background)
Normal mast height
Bell cycle: ring when gate lowers and don’t ring when down then ring when the gate rises.
2nd signal
Base: safetran 70s
Gate mech: RACO gate mech. Safetran S20 look
Bell: WCH type 2 (Gen) (slightly lowered in tone)
Gate striping: new
Gate lights: WCH red LEDs
Cantilever: safetran 1990s design (in front of gate)
Lights: Safetran Incandescents
Frames: safetran 12 by 20 inch
Junction box: safetran
Has a STOP ON RED SIGNAL sign.( black letters on white background)
No track sign
Short mast(C&NW style)
Bell cycle: ring when the gate goes down and when it goes up but doesn’t ring when the gate is down.
I will try to make this in Roblox
Known as SignalMan9292 on Youtube.
Known as BNSFSignalMan9292 on Roblox.
I make games on Roblox if you want to check those out.
