Ellington Parkway (US 31A Truck/TN 272), Lewisburg, TN
*originally recorded on 2-10-23*
Signal on the left: 6 pairs of WCH 12x24 inch lights with WCH 2nd Generation LEDs, an NEG electronic bell, an Invensys Rail gate mechanism, and NEG LED gate lights.
Signal on the right: 6 pairs of WCH 12x24 inch lights with WCH 2nd Generation LEDs, an Invensys Rail gate mechanism, and NEG LED gate lights.
After I caught CSX L693 shoving down the branch, I went over to this crossing to wait for the return trip back up the branch, as it was the last crossing on the CSX Belfast Branch I had yet to record. Eventually, after a little while of waiting, L693 came back through on their journey back up the branch, with the GP40-2 pulling just the caboose. It appears that the four cars they had with them on the way down were all dropped off at the two customers they worked, and they didn't have any to pick-up.
This crossing is a fairly decent one, though it is just a somewhat boring modern CSX install. Previously, when this was just a three-lane road, there were a pair of gateless L&N cantilevers here. The far signal was an FS/WCH cantilever that appears to have had at least one of the mast lights replaced (street view shows what appears to be an MI 12x20 mixed with some kind of 12x24, possibly Safetran, though I don't know if the MI light would've been original), though it still retained its original mechanical bell and MI 12x20 inch overhead lights. The near signal was an MI cantilever, though it appears that all of the lights on it had been replaced with 12x24 inch lights over the years. In the early 2010s, the road here was widened to five lanes (though four lanes divided at the crossing), and the road that used to intersect right before the crossing was realigned a bit south to move the intersection further away from the crossing, and the signals here were replaced with the current ones as a result.
Since then, however, basically nothing has changed here other than the apparent replacement of all of the gate lights at some point. The MI cantilever that'd been here was later reused at the 2nd Avenue crossing further west along this branch.
This crossing is a fairly large one though, one of the largest on the S&NA North and easily the largest on the Belfast Branch. No idea why each signal has an extra pair of overhead lights, but I'm guessing it's either for visibility, or to have an extra pair over each of the bike lanes here. Also not entirely sure why CSX chose to install only one NEG e-bell here, given that most of their installs along the S&NA North around this time typically featured two e-bells, and the fact that this is also a fairly large crossing. It appears that something had recently hit the closer signal, as the front-left mast light was knocked out of alignment and the wind-guard also seems to have been twisted back a bit, which I think contributed to the problem described below...
As you can see, the gate arm on the closer signal kept lowering and raising after the train had passed. This was because it kept running into the wind-guard on the signal. This is due to the fact that the gate mechs here are S-60s, and a feature of them is that if they run into an obstruction when raising, they were stop and lower back down a bit to try raising again, eventually lowering for longer periods of time if the obstruction doesn't clear. Unfortunately, as the obstruction that it ran into was the fairly-permanently-fixed wind guard, it kept raising and lowering for around 6 and a half minutes straight, causing quite the issue with traffic. Eventually, it was able to get the gate arm all the way up so the crossing was fully able to deactivate, but I still got it called into CSX so they could get a maintainer out here to fix it (and I suspect the wind guard and the light have since been straightened out). It appears that it's been this way for a little while though, as part of the striping on the closer gate arm's been worn-off where it was rubbing against the wind-guard!
http://www.rxrsignals.com/Tennessee/G-Q ... Ellington/
