Hi,
Just wondering if anyone know anything a bout this small scale crossing. The crossbuck was missing when I accuired it. But the lights work and are 115 volt. The signs have the glass reflectors in them. The housings are 4-1/2" the lens are 4". The stop on red sign is 13" wide and 11-3/8 tall. The 2 track sign is 13-3/4" wide and 9" tall. The pole is 2-1/4"x10' and has the final on top. The base is 8-1/2"x8-1/2" and 10" tall. It also has a wig wag flasher made by time-o-matic company that is 115 volts ac 60 cycles also. model 53 form 61K40 serial number 177592 amps per circuit 15. I have posted the photo's on photobucket since they are so large. Use the link below.
Thanks, Ed
http://s563.photobucket.com/albums/ss76 ... Volt%20AC/
Small scale wrrs signal lights
realtrainhorns
Ed Leach
Re: Small scale wrrs signal lights
I don't know a great deal about signals themselves, but those lights look to be standard 8 inch lights still in use in some areas. The signs look pretty authentic also, except maybe scaled down a bit. Overall it is a pretty good looking signal though.
Do you know where the signal came from... like an amusement park, or zoo, or something to that effect?
realtrainhorns
I measured the housings and they are 4-1/2 diameter. The guy I got it from said it belong to his grandfather and didn't know where he go it. They are very detailed even has the side windows, so you can see from the sides if the lights are flashing. Even has the screen covered vents in the bottoms.
Thanks, Ed
Thanks, Ed
Ed Leach
realtrainhorns
I don't know much about crossing signals, since I pick this up I was able to get a full size crossing setup. Which I am now in the process of erecting. So I think if someone has a use for this I may be willing to part with it.
Ed Leach
realtrainhorns
I have added this to the for sale and trade section, Please use that listing if your comment is about purchase or trade.
Thanks, Ed
Thanks, Ed
Ed Leach
