I have not made any relay cases yet, I'm using ones from 3DTS. I may make some in the future.TommyBNSF wrote:Patrick, I love the relay cases in your pictures and videos. I am kind of a relay case nut if you want to call me that. Are you going to release them to the public or at least to me?
RRXingRick's Signals
- rrxingrick
Re: RRXingRick's Signals
- rrxingrick
Hey, You wouldn't by any chance happen to have a dew detailed shots of that Griswold cantilever in the background would you? I'm preparing to release a high detail one of my own and I just wanted to see how much more detail mine has compared to that one. ThanksCaltrain927 wrote:Here's a screenshot thread for Patrick's MSTS crossing signals.
Patrick's site is down so if anyone wants these signals just ask me.
- Caltrain927
Sure, these are Jovet's Griswold Cantilevers,rrxingrick wrote:Hey, You wouldn't by any chance happen to have a dew detailed shots of that Griswold cantilever in the background would you? I'm preparing to release a high detail one of my own and I just wanted to see how much more detail mine has compared to that one. ThanksCaltrain927 wrote:Here's a screenshot thread for Patrick's MSTS crossing signals.
Is there anyway I can get these crossing signals. I need them for a route I'm building. I am also missing redlightoff.ace for the lights. I downloaded the lights from the MSTS downloads but I need the rest of the set. Can someone send them to me??
PM Caltrain927, say that you want a request for rrxingricks signals. Give your email in the PM so that he knows where to send them. You should get them in a couple of days.tash1285 wrote:Is there anyway I can get these crossing signals. I need them for a route I'm building. I am also missing redlightoff.ace for the lights. I downloaded the lights from the MSTS downloads but I need the rest of the set. Can someone send them to me??
- Smjh1979
- Site Admin
I've got the file. I'm assuming it was for the Dialight/Safetran FLX-4000 textures. I've re-uploaded both the 12"x20" and 12"x24" ZIP files with the file inside.
For those who are missing the file, I've uploaded it by itself at http://www.rxrsignals.net/MSTS_Download ... ghtoff.ace
dnewman1227
rrxingrick wrote:First off, Make sure they are set as a LevelCR entry in the .ref file of your route. If they are set as a static entry, you're not going to be happy. You need to place the light control units perfectly over the light heads, accomplish this by copying the x/y/z coordinates from the individual light heads to the individual light control units. Keep in mind that for every light head, you need 1 light control unit. For best results, place the LevelCR portions of the light controls all in the same place, all at the same time. For the animation, set the gate close/open time to how long you want the lights to stay on in conjunction with the gates on your signal going up (Example, you have your gates set to raise in 7 seconds, and you want your lights to shut off when the gate is about 85% up, set the lights to about 5.75 - 6 seconds.) If you are building a gateless crossing, its quite simple, the longer you set the gate open/close time, the longer it will take for the lights to shut off after the train has passed (Example, if you want the lights to shut off almost instantly, set the time to .1, if you want them to take like 5 seconds to shut off, set the time to around 5 seconds) Hope this helps.dnewman1227 wrote:I did receive this set. Unfortunately I don't see any instructions on how to install them. Just like with any other crossing set, I'm trying to figure out the light control w/o the directions.
BTW, Do anyone know the animation speed to the light control?
dnewman1227
Hey Patrick,
These crossings you created are WAAAAAY cooler than the previous set that I had. More realistic. The flashers, to say that they were suppose to be a "static" object, I've slightly converted them to "levelcr" objects along with the light controls due to a G-C issue. I've tested them out after placing them at the crossings ( having the minimum activation distance set @110.0 meters ) and they worked just great!! Also, I've used the negative numbers for the flashers to animate ( best setup: -0.0333 ).
Too bad there are no US&S Xings in the set, but I'm using the WCHs for the time being ( since they're slighty identical to each other ) along with the Safetrans for the Texas Panhandle Route, The Hereford Sub.
But Once again, I've really appreciated your assistance for showing me how to work this set.
Couple questions...
Am I to assume I still need to PM CalTrain (as mentioned in an earlier post) to request the signal package, above and beyond what's available in the MSTS downloads section on the main site, in order to get everything I need for these signals?
Is there a how-to included in that package? Or, does anyone have a how-to? (At least, whatever I need to copy/paste into the .ref file...)
Thanks
Thanks
- Smjh1979
- Site Admin
Haven't heard so much as a peep in the last 6 months or so.
