But everything was frozen solid, including the washer on the back door which was rust welded beyond the capabilities of any penetrating oil or heat!
Here is the rust laden inside and components in TERRIBLE shape. Luckily I have all the spare parts to make this bell like new again.
This gong would be ok ( inside will have some pitting) after some blasting, but I am going to throw it aside and use a spare from a donor "Teardrop"
While I love mechanical bells, I am starting to appreciate the electronic bells and their practical use and solution to the many things that can fail on mechanical bells. Pests are a big problem and once a bell is so old and rusted together, it would be hard to justify heating, oiling, breaking, welding, tapping, to get these darn critters out, they really can take over.
On a side note, I even noticed a defect with the pretty darn solid design of the Western Cullen Hayes electronic bell. While the casting is great and weatherproof, they need to install a rubber gasket around the speaker on the bottom. Dust can blow up and inside and collect on the top of the circuit board and possibly short it out. If you have one like that, make sure you have discharged any static from your body (touch a door knob) and use a soft brush to agitate the dust while running a shop-vac vacuum hose above.
As you can see, some heat was needed to salvage the clapper from the otherwise rust-welded and rotted assembly.
Stay tuned to continued work on these and it is going to take a little patience to get these bells into good shape.
Mike
