I didn't see the nearby bus stop, thanks for answering my question.
I was actually referring to the traffic light blocking where the crossbuck would normally be. But it would help with visibility too if a bus was there.
Anyways, I found this Teardrop bell at Corrigan Road, Noble Park which is not used. A Westinghouse bell (as seen on the gate mast) is used instead. But for some reason, they haven't removed the teardrop bell and it just sits there disused. https://www.google.com.au/maps/@-37.961 ... 312!8i6656
I've talked about the Ryans Road level crossing before. But basically, when the built the Pakenham bypass, they had to close the road at the crossing. But they forgot to remove the signals and as a result, the signals were left there protecting no one!
They were still there in 2010. (It's even active!) https://www.google.com.au/maps/@-38.083 ... 312!8i6656
They've since been removed, but still pretty funny.
