Tracks out of service
Ethan the Railfanner
Re: Tracks out of service
Post by Ethan the Railfanner »
freebrickproductions wrote:A later SOU install:
https://www.google.com/maps/@33.2910675 ... !8i6656?hl
Did you notice the remains of some railroad tracks look like a snake there?
https://www.google.com/maps/@33.2909051 ... 6656?hl=en
I bet you noticed this, but this abandoned crossing had its gate arm likely stolen sometime around 2013-2016 though.
https://www.google.com/maps/@33.2909006 ... 6656?hl=en
https://www.google.com/maps/@33.2908885 ... !8i6656?hl
Ethan the Railfanner; The main railroad crossing photographer of Southeast United States, while also slowly expanding elsewhere across the U.S.
If you have any crossing photos that you would like for submissions:
DM me on the forum
DM me on Discord (ethantherailfanner)
Gate mech probably failed and the gate arm was removed.
NathanFromEngland
Post by NathanFromEngland »
Why couldn't they just chain the gates upright?
Cheaper not to, or they mothballed the line in hopes of the line going back into service prior to abandonment, and then just had it abandoned when no service was going to return.
LARDLOGO
Post by LARDLOGO »
Slight update to the crossing at Bear Mountain Road in Arvin, California. The eastward signal has had all but one of it's lights removed. The gate had it's lights removed and it was also removed from the signal. It's hanging by the chain. The grade has also been poorly paved over.
https://goo.gl/maps/FqBwUnu9TZ82
LARDLOGO
Post by LARDLOGO »
Hobsonway, Blythe, CA- Yellow EXEMPT signs have been placed on the median signals.
https://goo.gl/maps/s6Sn7Kmuam42
https://goo.gl/maps/V5onGABEHCC2
Gates on east facing signals have been removed.
https://goo.gl/maps/nuoqD1iQVBz
Grade has been removed and paved over.
https://goo.gl/maps/ykXGePJ9hNL2
NathanFromEngland
LARDLOGO wrote:Hobsonway, Blythe, CA- Yellow EXEMPT signs have been placed on the median signals.
...and not too far away :LOL3:
https://www.google.com/maps/@33.6103254 ... 312!8i6656
Also i decided to keep on looking. Streetview however isn't reliable, as the pictures haven't been updated in a decade so i had to rely on Google Earth.
https://www.google.com/maps/@33.6030154 ... 328!8i1664
https://www.google.com/maps/@33.5884859 ... 328!8i1664
https://www.google.com/maps/@33.6175965 ... 312!8i6656
https://www.google.com/maps/@33.6321423 ... 328!8i1664
Remains of a small trestle.
https://www.google.com/maps/@33.6393121 ... a=!3m1!1e3
Another trestle, and what appears to be a relay case.
https://www.google.com/maps/@33.6466915 ... a=!3m1!1e3
After a while the line appears to head through the mountains, so i had to chase the remains of trackage to the nearest possible source.
https://www.google.com/maps/@33.8630535 ... 328!8i1664
Another trestle.
https://www.google.com/maps/@34.0262705 ... a=!3m1!1e3
...The line eventually seems to split into two and onto active railroad tracks, not sure if those new signals are even active at all, unless that remainder of the line is used for car storage.
https://www.google.com/maps/@34.0846961 ... 328!8i1664
On the other side.
Crossbuck crossing to the left, signals to the right.
https://www.google.com/maps/@33.5739307 ... 328!8i1664
Abandoned railcars?
https://www.google.com/maps/@33.5366423 ... a=!3m1!1e3
A WCH installation with E-Bells and WCH Clear LEDS.
https://www.google.com/maps/@33.5274029 ... 328!8i1664
Back in 2013, the crossing was still recieving power until either the light failed or the relay case was eventually disconnected.
https://www.google.com/maps/@33.290857, ... 6656?hl=en
NathanFromEngland wrote:Back in 2013, the crossing was still recieving power until either the light failed or the relay case was eventually disconnected.
Definitely disconnected. The gate is being held up to the mast, and naturally it would fall if there was no power.
Charlotte, NC. Appears to have just recently gone out of service:
https://www.google.com/maps/@35.2804727 ... 312!8i6656
https://www.google.com/maps/@35.2806898 ... 312!8i6656
Was still used back in 2014:
https://www.google.com/maps/@35.280577, ... 312!8i6656
Though by 2016, the rails were rusted over:
https://www.google.com/maps/@35.2805537 ... 312!8i6656
And 2018 shows that they were cut-back:
https://www.google.com/maps/@35.2805563 ... 312!8i6656
freebrickproductions wrote:Charlotte, NC. Appears to have just recently gone out of service:
Interesting. The tracks' severance is the only sign it's out of service as well..
