Whatever works for them. Besides, this works a bit better since it's easier to wire in through the signal masts.TrickyMario7654 wrote:Seems a bit strange that they would use a crossing light rather than a beacon...freebrickproductions wrote:Crossing indicator. Lets the train crews for that light rail/commuter rail line know that the crossing signals have activated and if the gates have lowered or not as well.TrickyMario7654 wrote:Anyone know why there's a crossing light facing towards the track at this crossing?
https://www.google.com.au/maps/@38.6329 ... 312!8i6656![]()
Google Maps Scavenger Hunt
In addition to that, visibility is probably higher as well than just a small beacon.freebrickproductions wrote:Whatever works for them. Besides, this works a bit better since it's easier to wire in through the signal masts.TrickyMario7654 wrote:Seems a bit strange that they would use a crossing light rather than a beacon...freebrickproductions wrote:Crossing indicator. Lets the train crews for that light rail/commuter rail line know that the crossing signals have activated and if the gates have lowered or not as well.TrickyMario7654 wrote:Anyone know why there's a crossing light facing towards the track at this crossing?
Muncie, Indiana.
- They just had to get that gate protector put on there somehow...
https://www.google.com/maps/@40.1973539 ... 312!8i6656 - Active crossing... had just activated as the Google Car was crossing:
https://www.google.com/maps/@40.2043502 ... 328!8i1664
https://www.google.com/maps/@40.2043696 ... 328!8i1664 - This one might have been posted previously, but still nice! https://www.google.com/maps/@40.1715301 ... 312!8i6656
- All 8 inch equipment (as of 2015) at this huge crossing.
https://www.google.com/maps/@40.1880995 ... 312!8i6656 - These might be repeats too, but still worth another look:
https://www.google.com/maps/@40.1895969 ... 312!8i6656
https://www.google.com/maps/@40.1898762 ... 312!8i6656 - Interesting: https://www.google.com/maps/@40.1905867 ... 312!8i6656
- 3 track crossing with just 8 inch lights as protection: https://www.google.com/maps/@40.1917979 ... 312!8i6656
- Lex-C's on one side, but regular 8 inch lights on the other:
https://www.google.com/maps/@40.191878, ... 312!8i6656
https://www.google.com/maps/@40.1915981 ... 312!8i6656 - All Lex-C's here: https://www.google.com/maps/@40.1912603 ... 312!8i6656
Here too: https://www.google.com/maps/@40.1875135 ... 312!8i6656 - I'm guessing at one time this was mounted to those posts, like on the other side. https://www.google.com/maps/@40.1904547 ... 312!8i6656
- One of them was happy to see the Google Car... the other, not!
https://www.google.com/maps/@40.1886956 ... 312!8i6656 - 4 signals in a residential area and not a single bell: https://www.google.com/maps/@40.1895561 ... 312!8i6656
- No mast lights: https://www.google.com/maps/@40.1974923 ... 312!8i6656
- Look closely behind the telephone pole: https://www.google.com/maps/@40.1837473 ... 312!8i6656
Peek a boo: https://www.google.com/maps/@40.1837899 ... 312!8i6656 - We've got a leaner: https://www.google.com/maps/@40.1871331 ... 312!8i6656
Saw a video of this crossing back in 2012... listen to what the bell sounded like! Wonder if it's been fixed?
http://www.rail-videos.net/video/view.php?id=13421
- TrickyMario7654
Here's something you don't see everyday, a cantilever signal being replaced with a mast signal! This crossing at Diggers Rest in Victoria had two cantilever signals in 2010 (with newer 'flat' gates and Hybrid bells).
https://www.google.com.au/maps/@-37.626 ... 312!8i6656
Fast forward to 2014, and one of the cantilever signals have been replaced with a mast signal! An extra signal was also installed in its place.
The other side is pretty much the same as before.
Out of interest, the 'flat' gates were replaced with A-gates and the Hybrid bells were swapped out for E-Bells. I figured that all these changes would have been made in 2012 when they extended suburban services to Sunbury (from Watergardens/Sydenham station).
Here's another oddity I found. This crossing has "GIVE WAY TO TRAINS" signs even though there's light and bells at this crossing!
https://www.google.com.au/maps/@-38.340 ... 328!8i1664
https://www.google.com.au/maps/@-38.339 ... 328!8i1664
By 2009, someone probably noticed the signs and removed them later. They also replaced the Hybrid bell with an E-Bell...
https://www.google.com.au/maps/@-38.340 ... 312!8i6656
When GSV revisited the crossing in 2013, the crossing had been upgraded to a gated crosssing. Seems like a waste of money to replace the bell if the whole signals themselves were gonna get replaced.
The same thing happened at this crossing further down the line. In 2007, there's a McK&H Teardrop bell at the location.
https://www.google.com.au/maps/@-38.364 ... 328!8i1664
By 2009, out with the McK&H Teardrop, in with the GS E-Bell!
https://www.google.com.au/maps/@-38.364 ... 312!8i6656
By 2013, crossing upgraded with gates!
I know CSX has done that a fair amount.TrickyMario7654 wrote:Here's something you don't see everyday, a cantilever signal being replaced with a mast signal! This crossing at Diggers Rest in Victoria had two cantilever signals in 2010 (with newer 'flat' gates and Hybrid bells).
- TrickyMario7654
Each time GSV went through this crossing, the bell was different!
In 2007, it had a McK&H Teardrop bell...
https://www.google.com.au/maps/@-38.044 ... 328!8i1664
By 2010, it had been replaced with a WCH Mechanical Bell.
https://www.google.com.au/maps/@-38.044 ... 312!8i6656
By 2015, that had been replaced with a Safetran E-Bell!
Seems stupid to install a new Mechanical bell, only to replace it with an E-Bell a few years later...
Partly installed flashing lights signals...
https://www.google.com.au/maps/@-37.939 ... 328!8i1664
A few years later...
https://www.google.com.au/maps/@-37.939 ... 312!8i6656
- ToledoRailfan
Something happened to the gate!
https://www.google.com/maps/@35.6678937 ... 1664?hl=en
Active crossing, Panhandle, Texas:
https://www.google.com/maps/@35.3546666 ... 6656?hl=en
https://www.google.com/maps/@35.3545116 ... 6656?hl=en
It could be malfunctioning because I could not find a train.
Active crossing, Borger, Texas:
https://www.google.com/maps/@35.6788649 ... 1664?hl=en
https://www.google.com/maps/@35.6790182 ... 1664?hl=en
These signals are half buried in snow!
https://www.google.com/maps/@41.2715324 ... 6656?hl=en
https://www.google.com/maps/@41.271691, ... 6656?hl=en
https://www.google.com/maps/@41.2718903 ... 6656?hl=en
Kind of odd that the gates are missing stripes on one side.
https://www.google.com/maps/@41.2718644 ... 1664?hl=en
https://www.google.com/maps/@41.2717207 ... 1664?hl=en
Cool old 8'' signals with split crossbucks and teardrop bells!
https://www.google.com/maps/@41.3259281 ... 1664?hl=en
https://www.google.com/maps/@41.3261248 ... 1664?hl=en
This crossing only has one teardrop bell.
https://www.google.com/maps/@41.3214547 ... 1664?hl=en
https://www.google.com/maps/@41.32177,- ... 1664?hl=en
Actually, there is a train:ToledoRailfan wrote:Active crossing, Panhandle, Texas:
https://www.google.com/maps/@35.3546635 ... 6656?hl=en
The signals are deactivated once Street View passes on by:
https://www.google.com/maps/@35.3546619 ... 6656?hl=en
These also have 7" gate lights. Man, those things are really huge!ToledoRailfan wrote:These signals are half buried in snow!
Classic cantilever signals near Niagara Falls:
https://www.google.com/maps/@43.0831549 ... 312!8i6656
Another pair of classics:
https://www.google.com/maps/@43.1303553 ... 312!8i6656
Some really classic signals here!
https://www.google.com/maps/@43.1223647 ... 312!8i6656
A couple of older gated signals here across the border, though the original 8 inch lights have been replaced:
https://www.google.com/maps/@43.1328223 ... 312!8i6656
https://www.google.com/maps/@43.1334211 ... 312!8i6656
More classic signals back in New York state:
https://www.google.com/maps/@42.9746597 ... 312!8i6656
https://www.google.com/maps/@42.9749435 ... 312!8i6656
