Tracks out of service
- brett nc railfanner
Re: Tracks out of service
Abandoned cantilever signal in Forest City, North Carolina:
https://www.google.com/maps/@35.3415989 ... 312!8i6656
continuing down the line:
https://www.google.com/maps/@35.3433039 ... 312!8i6656
https://www.google.com/maps/@35.3443117 ... 312!8i6656
https://www.google.com/maps/@35.3494368 ... 312!8i6656
https://www.google.com/maps/@35.3521006 ... 312!8i6656
https://www.google.com/maps/@35.3521768 ... 312!8i6656
Another abandoned cantilever:
https://www.google.com/maps/@35.3534425 ... 312!8i6656
Abandoned gateless signal:
https://www.google.com/maps/@35.3564079 ... 312!8i6656
More old signals on the line:
https://www.google.com/maps/@35.3571676 ... 312!8i6656
https://www.google.com/maps/@35.3582536 ... 312!8i6656
I'm surprised at the stuff still left on this line after being turned into a rail trail.
https://www.google.com/maps/@35.3769662 ... 312!8i6656
https://www.google.com/maps/@35.3839148 ... 312!8i6656
The line after that has been completely turned into a rail trail.
Looking up the DOT number on that first crossing, apparently that was the Thermal Belt Railway and, according to the FRA, was officially closed in 2017.
According to Wikipedia, the only thing left along the line is a small transloading operation:
https://en.wikipedia.org/wiki/Thermal_Belt_Railway
Out of service spur in El Paso, TX:
https://www.google.com/maps/@31.7806634 ... 384!8i8192
https://www.google.com/maps/@31.7813265 ... 384!8i8192
https://www.google.com/maps/@31.7892304 ... 384!8i8192
https://www.google.com/maps/@31.7918356 ... 384!8i8192
https://www.google.com/maps/@31.7950445 ... 384!8i8192
https://www.google.com/maps/@31.795644, ... 384!8i8192
https://www.google.com/maps/@31.797349, ... 384!8i8192
https://www.google.com/maps/@31.8068161 ... 384!8i8192
https://www.google.com/maps/@31.8068255 ... 384!8i8192
This crossing is now gone. http://www.rxrsignals.com/Michigan/L-Q/Owosso/Chipman/
https://www.google.com/maps/@42.9921373 ... 312!8i6656
Edit: Woops it wasn't the same crossing.
Last edited by brett nc railfanner on Tue Dec 03, 2019 12:52 am, edited 1 time in total.
Nope, that's a different crossing. Check the background scenery to make sure it matches up.brett nc railfanner wrote: Mon Dec 02, 2019 1:45 am This crossing is now gone. http://www.rxrsignals.com/Michigan/L-Q/Owosso/Chipman/
https://www.google.com/maps/@42.9997182 ... 312!8i6656
Oops, looked like similar equipment so I assumed it was the same crossing, and it was also late so I was tired, sorry about that.ZachL wrote: Mon Dec 02, 2019 9:56 amNope, that's a different crossing. Check the background scenery to make sure it matches up.brett nc railfanner wrote: Mon Dec 02, 2019 1:45 am This crossing is now gone. http://www.rxrsignals.com/Michigan/L-Q/Owosso/Chipman/
Abandoned spur in Wichita Falls, Texas:
https://www.google.com/maps/@33.9035727 ... 312!8i6656
Abandoned streetrunning spur in Austin, Texas:
https://www.google.com/maps/@30.2576506 ... 384!8i8192
https://www.google.com/maps/@30.251167, ... 312!8i6656
Only trace of track ever being here is the crossing grade:
https://www.google.com/maps/@30.2582264 ... 384!8i8192
Wonder what happened here? https://www.google.com/maps/@30.2632557 ... 312!8i6656
https://www.google.com/maps/@30.2632416 ... 312!8i6656
Hopefully they reused those signals because they were less than 10 years old when they were removed.
Remnants of an old spur in Georgetown, Texas:
https://www.google.com/maps/@30.6745939 ... 384!8i8192
Another abandoned grade in Hearne, Texas:
https://www.google.com/maps/@30.8818406 ... 312!8i6656
More spur remnants in Franklin, Texas:
https://www.google.com/maps/@31.024696, ... 312!8i6656
Another abandoned spur in Jacksonville, Texas:
https://www.google.com/maps/@31.9642618 ... 312!8i6656
Some abandoned signals in Whitehouse, Texas:
https://www.google.com/maps/@32.2267201 ... 312!8i6656
Going up the line:
https://www.google.com/maps/@32.2337531 ... 312!8i6656
https://www.google.com/maps/@32.2405231 ... 312!8i6656
Turns active after that.
- KCMO Railfan
Found this abandoned spur in Independence, MO
https://www.google.com/maps/@39.106915, ... authuser=0
Note, this spur once served the Independence Power and Light power plant in the 70's when the plant had coal service via train. The spur came off of the UP River Subdivision ( Which is east of Independence near the ammunition plant).
This spur along with the Active Pixley Spur was on the news back in 2014 as the city wanted to put in a commuter rail in. They also mentioned about bringing back the unused Rock Island St. Louis Subdivision, but plans must've fell through and they didn't put in the commuter rail.
Abandoned line in New London, North Carolina:
https://www.google.com/maps/@35.4261949 ... 384!8i8192
https://www.google.com/maps/@35.4286209 ... 384!8i8192
https://www.google.com/maps/@35.4437031 ... 312!8i6656
Unsure if this part is abandoned or not:
https://www.google.com/maps/@35.414102, ... 384!8i8192
Abandoned crossbuck crossings in Thomasville, North Carolina:
https://www.google.com/maps/@35.8838868 ... 312!8i6656
https://www.google.com/maps/@35.8806428 ... 312!8i6656
Looking at past imagery, it appears that it sees occasional use, but it's mostly unused.brett nc railfanner wrote: Tue Dec 03, 2019 3:33 pm Unsure if this part is abandoned or not:
- Ethan the Railfanner
I also noticed a rare "Do Not Climb" sign on the right cantilever. It seems like regardless, all crossing cantilevers are illegal to climb on unless you are a signal maintainer.freebrickproductions wrote: Tue Dec 03, 2019 4:23 pmLooking at past imagery, it appears that it sees occasional use, but it's mostly unused.brett nc railfanner wrote: Tue Dec 03, 2019 3:33 pm Unsure if this part is abandoned or not:
And based on my logic, I'm actually certain that the crossing is now out of service.
Ethan the Railfanner; The main railroad crossing photographer of Southeast United States, while also slowly expanding elsewhere across the U.S.
If you have any crossing photos that you would like for submissions:
DM me on the forum
DM me on Discord (ethantherailfanner)
DM me on the forum
