Based on what I can read of the link (which should be reposted, flat train), it's a Bryant Zinc bell, more than likely.Nascar Fan007 wrote: Sun Feb 09, 2020 10:15 pmLink gives me an error.flat train wrote: Sun Feb 09, 2020 7:41 pm What about this bell,
https://archive.org/details/BryantZincR ... 3/mode/2up
What type of bell?
Re: What type of bell?
flat train
I will try to redo the link,freebrickproductions wrote: Mon Feb 10, 2020 12:56 amBased on what I can read of the link (which should be reposted, flat train), it's a Bryant Zinc bell, more than likely.Nascar Fan007 wrote: Sun Feb 09, 2020 10:15 pmLink gives me an error.flat train wrote: Sun Feb 09, 2020 7:41 pm What about this bell,
It literally says on that document what that bell is...flat train wrote: Mon Feb 10, 2020 12:06 pmI will try to redo the link,freebrickproductions wrote: Mon Feb 10, 2020 12:56 amBased on what I can read of the link (which should be reposted, flat train), it's a Bryant Zinc bell, more than likely.Nascar Fan007 wrote: Sun Feb 09, 2020 10:15 pmLink gives me an error.flat train wrote: Sun Feb 09, 2020 7:41 pm What about this bell,
flat train
I know but the design is different from the usual design. Also I knew it was a 0666 because it says that.freebrickproductions wrote: Mon Feb 10, 2020 3:57 pmIt literally says on that document what that bell is...flat train wrote: Mon Feb 10, 2020 12:06 pmI will try to redo the link,freebrickproductions wrote: Mon Feb 10, 2020 12:56 amBased on what I can read of the link (which should be reposted, flat train), it's a Bryant Zinc bell, more than likely.Nascar Fan007 wrote: Sun Feb 09, 2020 10:15 pmLink gives me an error.flat train wrote: Sun Feb 09, 2020 7:41 pm What about this bell,
https://archive.org/details/BryantZincR ... 3/mode/2up![]()
Well, there ain't much mystery about them here, outside of the questions of how they worked and if any still survived.flat train wrote: Mon Feb 10, 2020 9:01 pmI know but the design is different from the usual design. Also I knew it was a 0666 because it says that.freebrickproductions wrote: Mon Feb 10, 2020 3:57 pmIt literally says on that document what that bell is...flat train wrote: Mon Feb 10, 2020 12:06 pmI will try to redo the link,freebrickproductions wrote: Mon Feb 10, 2020 12:56 amBased on what I can read of the link (which should be reposted, flat train), it's a Bryant Zinc bell, more than likely.Nascar Fan007 wrote: Sun Feb 09, 2020 10:15 pmLink gives me an error.flat train wrote: Sun Feb 09, 2020 7:41 pm What about this bell,
Also, worth pointing out how that bell cost $40 in 1911. In today's money, that'd run you out a good $1,082...
flat train
Does that say wrrs 1218? https://www.ebay.com/itm/Western-Railro ... SwwlJeQwhp
Are there different generations for teardrop bells & wrrs mechanicals bells? If so, may I ask the generation of some?
railrdc rossng
There's three different generations of Teardrops, haven't really noticed any with WRRS bells. And go ahead.pluey200 wrote: Mon Mar 02, 2020 12:52 pm Are there different generations for teardrop bells & wrrs mechanicals bells? If so, may I ask the generation of some?
Teardrop in Creston OH
https://goo.gl/maps/94prYN9BcMJEU1oN8
WRRS bell in Creston OH
https://goo.gl/maps/763QdgomoUv4Q33Z9
railrdc rossng
Can't really get a good view of the Teardrop, so IDK what gen it is, other than the fact that it doesn't appear to be a 1st Gen.
WRRS bell just looks like a standard WRRS bell.
