Signals getting damaged/destroyed
- NathanFromEngland
Re: Signals getting damaged/destroyed
A train strikes a truck here, which destroys a RACO cantilever and a gate.
Looks like this was the crossing, which was an old SCL install:
https://www.google.com/maps/@33.4016284 ... 384!8i8192
- NathanFromEngland
At least it wasn't the signal with the relay case next to it, the whole crossing (I assume?) would have to be entirely replaced!freebrickproductions wrote: Sat Dec 14, 2019 2:16 pm Looks like this was the crossing, which was an old SCL install:
https://www.google.co.uk/maps/@33.83184 ... 312!8i6656 Just like this crossing.
- Gametrain54321
I know this is late, but that is crazy seeing that old cantilever being thrown 180 degrees as if It was a baby throwing a plate of broccoli into the air. Shame it was destroyed, but at least it wasn't the one with the mechanical bell.
- NathanFromEngland
Here's a dumb Polish truck driver.
Can't tell if it also managed to hit the bungalow, the lights on the first angle seem to shut off soon after the train strikes the truck.
- Gametrain54321
It appears the relay bungalow was on the side he didn't hit, so it could've just been a sun glare, but it did appear the lights shut off. Otherwise though, he pretty much managed to destroy everything there except for 1 pair of lights.
- NathanFromEngland
The side(?) mounted lights took a nasty beating here.
- NathanFromEngland
Half of the crossing doesn't work here for some reason, i assume the cantilever that is closer must've fused out or something when the gate was damaged.
- Doge_Illinois
at 0:25, you can see a bit of a destroyed signal, the other signals gate got destroyed too, and then not too long after the new signal was up, the crossing got upgraded.
The crossing is on the site too:
http://www.rxrsignals.com/Illinois/R-Z/ ... ton/River/
The signal on the left was knocked down.
Last edited by Doge_Illinois on Mon Apr 20, 2020 11:19 am, edited 3 times in total.
- Doge_Illinois
In the beginning of the video, you can see a destroyed crossing. This was in Joplin after the 2011 tornado.
