Google Maps Scavenger Hunt
Ethan the Railfanner
Post by Ethan the Railfanner »
Active crossing in Sebree, Kentucky:
https://www.google.com/maps/@37.6067432 ... 312!8i6656
This crossing next door is also active too!
https://www.google.com/maps/@37.6077295 ... 312!8i6656
Ethan the Railfanner; The main railroad crossing photographer of Southeast United States, while also slowly expanding elsewhere across the U.S.
If you have any crossing photos that you would like for submissions:
DM me on the forum
DM me on Discord (ethantherailfanner)
Ethan the Railfanner wrote: Fri May 17, 2019 9:40 pm Active crossing in Sebree, Kentucky:
Some nice equipment in that area! Also, here's some defect detector work going on:
https://www.google.com/maps/@37.7136913 ... 312!8i6656
Damaged crossbuck:
https://www.google.com/maps/@37.8118391 ... 312!8i6656
Straight back to the L&N here, though the L&N-era searchlight and pure L&N install at the crossing is likely no more:
https://www.google.com/maps/@37.8704106 ... 312!8i6656
A nice classic crossing with a Safetran Type 3 e-bell:
https://www.google.com/maps/@37.866296, ... 312!8i6656
A nice pure 1980s CSX install with an interesting light arrangement on one of the signals:
https://www.google.com/maps/@37.8057857 ... 312!8i6656
https://www.google.com/maps/@37.8060962 ... 312!8i6656
Would certainly be cool to see in action.
Another classic crossing, this time bell-less!
https://www.google.com/maps/@37.7676822 ... 312!8i6656
A very old L&N signal with the original split cast-iron crossbuck!
https://www.google.com/maps/@37.7653718 ... 312!8i6656
Another classic bell-less install:
https://www.google.com/maps/@37.7663134 ... 312!8i6656
An interesting set-up here, especially for the parking lot, which has a set-up similar to the 1980s install above:
https://www.google.com/maps/@37.766378, ... 312!8i6656
https://www.google.com/maps/@37.7665026 ... 312!8i6656
https://www.google.com/maps/@37.7667367 ... 312!8i6656
Based on the positioning of the crossbuck and the "front" lights, it appears that it protects this side road:
https://www.google.com/maps/@37.7665295 ... 312!8i6656
A crossing with only one gate, which is a median signal:
https://www.google.com/maps/@37.7679758 ... 312!8i6656
https://www.google.com/maps/@37.7679831 ... 312!8i6656
Unusual placement for the lone crossbuck here:
https://www.google.com/maps/@37.7691572 ... 312!8i6656
https://www.google.com/maps/@37.7693107 ... 312!8i6656
A very nice pair of classic L&N-era cantilevers:
https://www.google.com/maps/@37.7769528 ... 312!8i6656
More classic signals, though a bit odd to see what appears to be a pair of old RACO/Safetran cantilevers on what's most likely an ex-L&N line:
https://www.google.com/maps/@37.773698, ... 312!8i6656
Another classic L&N crossing:
https://www.google.com/maps/@37.7792214 ... 312!8i6656
Classic crossing:
https://www.google.com/maps/@36.055938, ... 312!8i6656
Another classic crossing, though with an e-bell:
https://www.google.com/maps/@36.0551118 ... 312!8i6656
(These may have been posted before, I can't remember.)
freebrickproductions wrote: Sun May 19, 2019 6:13 pm Classic crossing:
Still there as of November 2018!
https://www.google.com/maps/@36.0552995 ... 384!8i8192
I have yet to get out to these crossings. I haven't had time at the moment though.
DM me on the forum
Ethan the Railfanner wrote: Sun May 19, 2019 7:00 pm
I'd probably put them on a very high priority then, especially the one with 8 inch lights and a mechanical bell.
If I were to guess, I'm thinking this is an old SCL install that once had 8 inch lights before it was upgraded to Safetran 12x24s by CSX in the late 90's/early 2000's
https://www.google.com/maps/@33.311615, ... 312!8i6656
DM me on the forum
Ethan the Railfanner wrote: Sun May 19, 2019 9:21 pm If I were to guess, I'm thinking this is an old SCL install that once had 8 inch lights before it was upgraded to Safetran 12x24s by CSX in the late 90's/early 2000's
Those lights may even date back to the 1980s! Although I'd say 1990s. They're a little too faded to be from the 2000s.
ZachL wrote: Sun May 19, 2019 10:22 pm
Probably late 90s/early 2000s. One is a darker-colored one that I believe Safetran made in the early to mid-2000s.
And based on the orientation and design of the bases, I'd wager that's most likely an old ACL install, as the ACL appears to have typically oriented their bases away from the road, while the SAL typically oriented them facing the tracks.
freebrickproductions wrote: Sun May 19, 2019 10:49 pm
Heh, I never noticed the base orientation on SAL/ACL signals. At least both companies have roots planted in my area for me to check out.
NathanFromEngland
Post by NathanFromEngland »
I've never seen a relay case attached to a signal before, the bracket is also very strange...
https://www.google.com/maps/@44.423552, ... 312!8i6656
What company is this?
https://www.google.com/maps/@44.5344082 ... 312!8i6656
Found a pretty cool US&S install, although sadly the signals were replaced.
https://www.google.com/maps/@44.9364769 ... 312!8i6656
