Tracks out of service
- brett nc railfanner
Re: Tracks out of service
https://www.google.com/maps/@33.8428686 ... 312!8i6656
https://www.google.com/maps/@33.7509811 ... 312!8i6656
https://www.google.com/maps/@33.7509213 ... 312!8i6656
https://www.google.com/maps/@33.7508106 ... 312!8i6656
https://www.google.com/maps/@33.7507257 ... 312!8i6656
https://www.google.com/maps/@33.7545512 ... 312!8i6656
https://www.google.com/maps/@33.7585606 ... 312!8i6656
Appears to be a triangle gate mechanism that's been modified?brett nc railfanner wrote: https://www.google.com/maps/@33.7507257 ... 312!8i6656
https://www.google.com/maps/@33.7508289 ... 312!8i6656
That or someone wants more lunch!cabman701 wrote:Appears to be a triangle gate mechanism that's been modified?brett nc railfanner wrote: https://www.google.com/maps/@33.7507257 ... 312!8i6656![]()
https://www.google.com/maps/@33.7509331 ... 312!8i6656
Defunct crossing in Toms River is starting to degenerate
https://goo.gl/maps/hyGLJ6UsUtz
https://goo.gl/maps/MyExBpejBmr
- ToledoRailfan
I just found out that the second crossing is to a State Park, I wonder if they kept the old crossbuck there on purpose.ToledoRailfan wrote:A very hidden bridge.
https://www.google.com/maps/@41.4719749 ... 6656?hl=en
A very interesting 45 degree crossbuck.
https://www.google.com/maps/@41.485295, ... 6656?hl=en
A pair of 45 degree crossbucks.![]()
https://www.google.com/maps/@41.4995447 ... 6656?hl=en
Although this crossing looks to still have power, I believe this line is out of service, at least for the time being:
https://www.google.com/maps/@38.1863194 ... !1e1?hl=en
Notice the light pointing down on the cantilever? It was like that in 2014 as well. https://www.google.com/maps/@38.1862261 ... 6656?hl=en
Also the tracks are quite rusty. On the plus side, both signals have inverted SORS signs!
Another crossing a little further southwest... 2 left sided cantilevers with 8 inch lights:
https://www.google.com/maps/@38.1767705 ... !1e1?hl=en
You can see further evidence of non-use as the tracks are pretty much buried in the dirt to the left of this crossing.
The line ends just 2 blocks southwest: https://www.google.com/maps/@38.1732698 ... 6656?hl=en
Going in the opposite direction about 20 miles, we find crossings with nearly brand new installs... and somwhat improving track conditions: https://www.google.com/maps/@38.3543796 ... 6656?hl=en
https://www.google.com/maps/@38.3182937 ... 6656?hl=en
There is MOW equipment visible on a siding to the right of this crossing: https://www.google.com/maps/@38.3300763 ... 6656?hl=en
Definitely a pretty large spur there. The more southern parts where it appears to be out of service is likely due to customers no longer using the line, whereas there could be customers further in that still actively use it.cabman701 wrote:Although this crossing looks to still have power, I believe this line is out of service, at least for the time being:
Here's where it connects up with a mainline:
https://www.google.com/maps/@38.6896058 ... ,17z?hl=en
Personally, I think this is more like a branch line than a spur. The varying condition of the tracks the fewer and fewer customers along it the further up it you go is certainly a condition of some branch lines I've seen.ZachL wrote:Definitely a pretty large spur there. The more southern parts where it appears to be out of service is likely due to customers no longer using the line, whereas there could be customers further in that still actively use it.cabman701 wrote:Although this crossing looks to still have power, I believe this line is out of service, at least for the time being:
