Geometrically Challenged shaped arms in Kingsland,AR
Posted: Fri Sep 30, 2011 10:58 pm
by legsbluetrain
I don't know the name of the road,I may have posted a topic in this forum of the crossing without a train.
Re: square gates in Kingsland,AR
Posted: Fri Sep 30, 2011 11:28 pm
by TrainmanKight
Who taught you shapes :LOL3:
Posted: Sat Oct 01, 2011 10:14 am
by Caltrain927
Someone failed Geometry :P
Posted: Sat Oct 01, 2011 2:52 pm
by legsbluetrain
I call them square because of the part that the gate is on on the mast is like a square,my friend calls them square gates also.I don't see crossings like that around Pine Bluff except the one at a paper mill.
Posted: Sun Oct 02, 2011 1:37 pm
by MD2020
The gate arm is rectangle shaped, just like any other standard gate arm in the US. The rear cover of the mechanism is square, but that's pretty normal also. The counterweight support arms are triangle shaped, and aren't very common. The only "square" thing I see in the pic other than the rear cover is the counterweights.
Posted: Tue Oct 04, 2011 9:27 pm
by legsbluetrain
MD2020 wrote:The gate is rectangle shaped, just like any other standard gate in the US. The rear cover of the mechanism is square, but that's pretty normal also. The counterweight support arms are triangle shaped, and aren't very common. The only "square" thing I see in the pic other than the rear cover is the counterweights.
That's what I meant,I know those counterweight supports are not common,but that's all I know that crossing for,that counterweight support,my friend calls them square gates,I know what he's referring to.
Posted: Wed Oct 05, 2011 5:24 am
by MD2020
We understand, you have a friend. Congradulations to you. Apparently he is geometrically challenged also. Congradulations to him as well. I understand how y'all get can along.
However, the gate is not square. Neither are the counterweight support arms. ...Seriously.
You should inform your friend.
Posted: Wed Oct 05, 2011 11:15 am
by legsbluetrain
MD2020 wrote:We understand, you have a friend. Congradulations to you. Apparently he is geometrically challenged also. Congradulations to him as well. I understand how y'all get can along.
Title has been changed.
Posted: Wed Oct 05, 2011 4:17 pm
by MD2020
legsbluetrain wrote:Title has been changed.
Sure has, heh heh... :ROFL:
