Do they still make Safetran Bells?
- ZachL
Re: Do they still make Safetran Bells?
Safetran mechanical and "Type-1" e-bells are no longer produced. However, I am not sure if they still make "Type-2" or "Type-3" e-bells.
They are still making type 3s, they are changing Every mechanical ones for type 3 on CN's Mont-Joli subdivision
- ToledoRailfan
Aren't Safetran Type-2 bells kind of rare?ZachL wrote:Safetran mechanical and "Type-1" e-bells are no longer produced. However, I am not sure if they still make "Type-2" or "Type-3" e-bells.
Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK.ToledoRailfan wrote:Aren't Safetran Type-2 bells kind of rare?ZachL wrote:Safetran mechanical and "Type-1" e-bells are no longer produced. However, I am not sure if they still make "Type-2" or "Type-3" e-bells.
Siemens still makes the Safetran Type 3.
Yes. US&S sells WCH mechanical bells though, but I don't know if they still put their own logo on the backs of them like they did for a while.nickrink wrote:Is WCH the only one who still makes mechanical bells?ZachL wrote:Safetran mechanical and "Type-1" e-bells are no longer produced. However, I am not sure if they still make "Type-2" or "Type-3" e-bells.
Correct. A Safetran Type-2 e-bell has an exposed area on the base, whereas an NEG e-bell has a metal ring around the base.freebrickproductions wrote: Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK..
Pages 11-12 here:nickrink wrote:Does anyone know where I can view bells on Siemens website?
https://w3.usa.siemens.com/mobility/us/ ... oducts.pdf
Pages 3-6 here:
https://w3.usa.siemens.com/mobility/us/ ... ystems.pdf
Actually, NEG and Safetran Type 2s are exactly the same externally. UP just likes to put metal rings around the bases of theirs. However, some NEG e-bells have a very similar base to that of a General Signals e-bell.ZachL wrote:Correct. A Safetran Type-2 e-bell has an exposed area on the base, whereas an NEG e-bell has a metal ring around the base.freebrickproductions wrote: Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK..
I guess you're right, although for a while it almost looked like CSX was doing the same:freebrickproductions wrote:Actually, NEG and Safetran Type 2s are exactly the same externally. UP just likes to put metal rings around the bases of theirs. However, some NEG e-bells have a very similar base to that of a General Signals e-bell.ZachL wrote:Correct. A Safetran Type-2 e-bell has an exposed area on the base, whereas an NEG e-bell has a metal ring around the base.freebrickproductions wrote: Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK..
https://www.google.com/maps/@28.033038, ... 312!8i6656
That's probably what it's mounted on showing through the base.ZachL wrote:I guess you're right, although for a while it almost looked like CSX was doing the same:freebrickproductions wrote:Actually, NEG and Safetran Type 2s are exactly the same externally. UP just likes to put metal rings around the bases of theirs. However, some NEG e-bells have a very similar base to that of a General Signals e-bell.ZachL wrote:Correct. A Safetran Type-2 e-bell has an exposed area on the base, whereas an NEG e-bell has a metal ring around the base.freebrickproductions wrote: Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK..
