Stop signs with flashing red lights.
Talk about other non-signal stuff here. Make sure to obey the rules though.
Megabox
Post by Megabox »
Have you seen them in your area? This four way stop intersection has stop signs with flashing red lights on top.
https://www.google.com/maps/@30.1493235 ... 384!8i8192
Re: Stop signs with flashing red lights.
You mean directly mounted to the stop sign (as you posted above), or just located at the same intersection?
Megabox
Post by Megabox »
Just located in the same intersection or directly mounted to the stop sign.
They're pretty common in California
LosAngelesMetro56
Post by LosAngelesMetro56 »
gedunk wrote: Fri Apr 10, 2020 2:05 pm They're pretty common in California
Yup. Lynwood has a few.
ColeD
Post by ColeD »
I see these more often at rural intersections where it's usually darker at night.
SirKrunch
Post by SirKrunch »
This is very common in many parts of Iowa... just a simple and cheap measure used to increase the visibility of the signs. On a intersection where only cross traffic has to stop, they will place a flashing yellow beacon or two on the diamond shaped approach sign to caution drivers to pay attention in case someone may pull out in front of them.
Well, :Censored:
UnionPacific4Life
Post by UnionPacific4Life »
There's a couple in and around St Louis.
Proud owner of a Safetran 3rd Gen M-Bell, a GS Type 2 bell, a dead GS type 1 bell, a WRRS M-bell, and a US&S H-2 searchlight signal.
Why does everyone copy my signature?
OG signal collection signature, I think. :LOL2:
LARDLOGO
Post by LARDLOGO »
BUMP
Sumas, WA- intersection of Cherry Street and Garfield Street. Only the stop signs on Cherry Street have the flashing lights.
https://goo.gl/maps/PjQZjxk6eztVGaGS7
https://goo.gl/maps/7Xcy8EhjUP18Bt1Z6
Goshen, WA- intersection of Everson Goshen Road and Smith Road. Streetview last went through here when it was a roundabout. Prior to 2011, this was a four way intersection with a four way flashing red beacon hung on the overhead powerlines. In late 2018/early 2019, they lowered the speed limit in the area to 35 and flashing reduced speed ahead signs were added in. The roundabout was removed earlier this year and the yield signs were replaced with flashing stop signs.
https://goo.gl/maps/a1Qoz2erU9cYqnnu9
https://goo.gl/maps/rmhwbRYUe6a5BQKP6
https://goo.gl/maps/VYuzsHUcu4m7jgDF7
https://goo.gl/maps/LKW1b2RaJemcNZ3g7
Bellingham, WA- flashing stop signs at the T-intersection of Northwest Avenue and Slater Road. Only Northwest Avenue has the flashing signs.
https://goo.gl/maps/iSmFj6QyqFrRkNGSA
https://goo.gl/maps/X6JxZESvku71VK8R7
