EMD Boulevard, Port Wentworth, GA
*originally recorded on 7-29-21*
Signal on the left: 2 pairs of Safetran 12x24 inch lights with Dialight Low Wattage LEDs, an NEG electronic bell, a Safetran gate mechanism, and NEG LED gate lights.
Signal on the right: 2 pairs of Safetran 12x24 inch lights with Dialight Low Wattage LEDs, an Safetran mechanical bell, a Safetran gate mechanism, and NEG LED gate lights.
After catching the SOFR's morning run, I went-up to this crossing on the CSX Charleston Subdivision that @Bigmindcreator TS had told me about to try and see if I could get a train here. Fortunately, after about 2 hours of waiting, CSX Q410 came through with an ET44AH leading an ES40DC on the head-end and another ET44AH working as the mid-train DPU.
This crossing's a rather nice one, featuring a nice late-70s SCL install, that still features at least some of the original equipment. It appears that in the late-90s or early 2000s, the (original Safetran mechanical?) bell on the far signal was replaced with a General Signals e-bell, and all of the lights here got upgraded to Safetran 12x24s around that same time in the early 2000s. The crossing remained unchanged for a few years until sometime between 2012 and 2016, when the signals here were upgraded to LED and the bell on the far signal was once again replaced, this time with an NEG e-bell. Since then though, no major changes appear to have occurred to these signals, thankfully. The remaining original Safetran mechanical bell at this crossing still sounds quite nice, though it seems to skip a few beats when the gate's almost down, likely due to the gate mechanism being a bit messed-up. Hopefully it remains here for a good while longer, but either way, I'm glad to have been able to record this crossing as well.
Also, there seems to be some disagreement with the name of the road this crossing's on. Google Maps calls it "EMD Boulevard" while CSX labeled it as Richard Avenue (IIRC) on the relay case. The FRA ain't much help either as they call it something different, and there aren't any street signs posted to clear-up the confusion any at all. I've personally decided to go with what Google labeled it as. Also seen through the trees in the background is I-95.
You can also hear the defect detector located next to this crossing going off after the train passes.
