Old pictures of railroad crossings in DeKalb IL
Talk about signal news here, including upgrades, downgrades, crossings out of service, abandoned, and so on here.
NSsignal
Post by NSsignal »
I finally was able to find pictures of the crossings in DeKalb before the wayside horns were installed. TommyBNSF will be excited. Please note I did not take any of these pictures. I found them on Railpictures.net and railroad pictures archives.
Here is a list.
6th street ASC E-Bell before the one way road change. 5/20/2006
http://www.rrpicturearchives.net/showPi ... ?id=395468
Another great 6th st picture 5/20/2006
http://www.rrpicturearchives.net/showPi ... ?id=395474
1st street before safetran m bell was replace and before Walgreens 11/20/2006
http://www.rrpicturearchives.net/showPi ... ?id=572739
7th st crossings old GRS type B gate mechs
http://www.rrpicturearchives.net/showPi ... ?id=896277
6th streets old GRS type B gate mech with wishbone gate
http://www.rrpicturearchives.net/showPi ... ?id=542611
1st streets old GRS type b and pedestrian single arm gate mechs.
http://www.rrpicturearchives.net/showPi ... ?id=247801
Pictures from rail pictures net
https://www.railpictures.net/showphotos ... C%7C%7C%7C
That’s all for now. I will add more picture links here in the future. Same with the people who took the photos.
Known as SignalMan9292 on Youtube.
Known as BNSFSignalMan9292 on Roblox.
I make games on Roblox if you want to check those out.
Re: Old pictures of railroad crossings in DeKalb IL
I'd recommend just linking to the pages you found those on, and some of the links don't even work it appears.
NSsignal
Post by NSsignal »
I noticed that. I will do that this morning
NSsignal
Post by NSsignal »
Rail pictures.net is weird with how the links work so I had to put those in a folder. Though I think I will just have it pull up the De Kalb search results instead
NSsignal wrote: Fri Mar 17, 2023 9:39 am Rail pictures.net is weird with how the links work so I had to put those in a folder. Though I think I will just have it pull up the De Kalb search results instead
Surely just linking to a page directly like this should work.
Also, just FYI, if you're adding something else onto a thread, and it's only been a couple of hours since your last post and no-one's responded since, just edit your post with the new stuff you want to add. I also assume this is one of the pictures you wanted to share earlier, which appears to have also been posted to rrpicturearchives. Those old WRRS signals and semaphore gate mechs are neat to see, though.
NSsignal
Post by NSsignal »
Got it. I’m new to this and there are some things that are missing that should be here in the forum. Also I hope wayside horns aren’t like an offensive thing for this community. And yes that is one of the pictures
