Just a thought... but I would assume the 12X20 lights are probably replacement lights and are quite a bit newer than the 8 inch lights.freebrickproductions wrote:It seems that the paint of 12x20 inch lights does better than the paint on 8 inch lights.ZachL wrote:Albany, GA
https://www.google.com/maps?q=3rd+Avenu ... 6,,0,-7.63
I know around here cantilever lights where the first ones that started changing over to 12 inch lights back in the 80's... mast lights usually stayed at 8 inches for awhile longer. The same thing happened when LED's came into the RR market... they started replacing cantilever lights with them primarily at first. I assume that was due to the LED's lasting longer and meaning less maintenance required and less danger for the maintainer needing to work out on the cantilever.
