Which pole exactly? Because if you are talking about the regular crossing poles, they measure 144 Inches.CSXtrainman13 wrote:Those are amazing! One question, what is the measurement on the poles? Is it 3 inches? Also, Can you do a Model 10 WCH crossing Gate?
Railroad Crossing Gate Diagrams
- NSrailfan4life
Re: Railroad Crossing Gate Diagrams
C.E.O. of Nelsons Trainsim Store Nelson Acosta: Our Webpage: http://trafficlight658.wix.com/nelsonstrainsimstore
- CSXtrainman13
- CSXtrainman13
For the Standard Mast, i meant for the width, or diameter.NSrailfan4life wrote:Which pole exactly? Because if you are talking about the regular crossing poles, they measure 144 Inches.CSXtrainman13 wrote:Those are amazing! One question, what is the measurement on the poles? Is it 3 inches? Also, Can you do a Model 10 WCH crossing Gate?
Cheers From Florida!
The standard widths are 4 inches and 5 inches.CSXtrainman13 wrote:For the Standard Mast, i meant for the width, or diameter.NSrailfan4life wrote:Which pole exactly? Because if you are talking about the regular crossing poles, they measure 144 Inches.CSXtrainman13 wrote:Those are amazing! One question, what is the measurement on the poles? Is it 3 inches? Also, Can you do a Model 10 WCH crossing Gate?
- CSXtrainman13
- NSrailfan4life
Got what you wanted, Hope ya like it! :D
- Attachments
- WCH Gate Crossing-Incandescent.png (31.43 KiB) Viewed 9554 times
- CSXtrainman13
Does it depend on the manufacture?freebrickproductions wrote:The standard widths are 4 inches and 5 inches.CSXtrainman13 wrote:For the Standard Mast, i meant for the width, or diameter.NSrailfan4life wrote:Which pole exactly? Because if you are talking about the regular crossing poles, they measure 144 Inches.CSXtrainman13 wrote:Those are amazing! One question, what is the measurement on the poles? Is it 3 inches? Also, Can you do a Model 10 WCH crossing Gate?
- NSrailfan4life
Nope. Its just what the railroad decides to install. For example. Most bells have fittings for 4 or 5 inches on the bases.CSXtrainman13 wrote:Does it depend on the manufacture?freebrickproductions wrote:The standard widths are 4 inches and 5 inches.CSXtrainman13 wrote:For the Standard Mast, i meant for the width, or diameter.NSrailfan4life wrote:Which pole exactly? Because if you are talking about the regular crossing poles, they measure 144 Inches.CSXtrainman13 wrote:Those are amazing! One question, what is the measurement on the poles? Is it 3 inches? Also, Can you do a Model 10 WCH crossing Gate?
- CSXtrainman13
Ok, so if a WCH signal would have a WCH E- Bell, what size would it need?
WCH makes their bells fit a 4 inch base, but they sell a 5 inch adapter from what I recall.
