It can appear to be stationery because GSV doesn't capture videoToledoRailfan wrote:That piece of equipment is pretty far from the crossing and appears to be stationary.ZachL wrote:I don't think it's a malfunction:ToledoRailfan wrote:Here is the crossing active, it appears to be a malfunction.
https://www.google.com/maps/@42.3201206 ... 6656?hl=en
https://www.google.com/maps/@42.3203451 ... 6656?hl=en
https://www.google.com/maps/@42.3201605 ... 6656?hl=en
- ZachL
Obviously it doesn't.ZachL wrote:It can appear to be stationery because GSV doesn't capture videoToledoRailfan wrote:That piece of equipment is pretty far from the crossing and appears to be stationary.ZachL wrote:I don't think it's a malfunction:ToledoRailfan wrote:Here is the crossing active, it appears to be a malfunction.
https://www.google.com/maps/@42.3201605 ... 6656?hl=enbut also, you don't know how far back the detection equipment is either, and it could have very well triggered the signals
I didn't really think that one through. https://www.google.com/maps/@42.3194883 ... 6656?hl=en
https://www.google.com/maps/@42.3207714 ... 6656?hl=en
Active views of a crossing in Luxembourg City.
https://www.google.com/maps/@49.6327785 ... 6656?hl=en
https://www.google.com/maps/@49.632894, ... 6656?hl=en
https://www.google.com/maps/@49.6329782 ... 6656?hl=en
https://www.google.com/maps/@49.6330713 ... 6656?hl=en
https://www.google.com/maps/@49.6329464 ... 6656?hl=en
https://www.google.com/maps/@49.6328635 ... 6656?hl=en
https://www.google.com/maps/@49.6327754 ... 6656?hl=en
https://www.google.com/maps/@49.6329857 ... 6656?hl=en
Another active crossing in Luxembourg City.
https://www.google.com/maps/@49.6441113 ... 6656?hl=en
This is kind of interesting, although I would think the sidelights would kind of do the job just fine on their own.
https://www.google.com/maps/@42.0043682 ... 6656?hl=en
Here is a pretty interesting setup.
https://www.google.com/maps/@42.0020987 ... 6656?hl=en
Looking at it again, it appears that the upper two red beacons are in a flash cycle. They're on-and-off as GSV goes through and passes on by the signal.ToledoRailfan wrote:Obviously it doesn't.ZachL wrote:It can appear to be stationery because GSV doesn't capture videoToledoRailfan wrote:That piece of equipment is pretty far from the crossing and appears to be stationary.ZachL wrote:I don't think it's a malfunction:ToledoRailfan wrote:Here is the crossing active, it appears to be a malfunction.
If you go far from the crossing in either direction the signals are still active, I would think that a crossing on a small industrial spur would activate when equipment is closer to the crossing, I can't image a setup like this would have the signals timeout if a train (or in this case a loco) isn't at the crossing though.
I noticed that too when I went further from the crossing, I thought that was pretty strange sense HAWK signals alternate when flashing, not simultaneously.ZachL wrote:Looking at it again, it appears that the upper two red beacons are in a flash cycle. They're on-and-off as GSV goes through and passes on by the signal.ToledoRailfan wrote:Obviously it doesn't.ZachL wrote:It can appear to be stationery because GSV doesn't capture videoToledoRailfan wrote:That piece of equipment is pretty far from the crossing and appears to be stationary.ZachL wrote:I don't think it's a malfunction:ToledoRailfan wrote:Here is the crossing active, it appears to be a malfunction.
- TrickyMario7654
Since GSV has been going around Melbourne recently, they've captured several of the dreaded LXRA signs seen at crossings that they're gonna grade separated...
Grange Road, Alphington
https://www.google.com.au/maps/@-37.779 ... 312!8i6656
Blackburn Road, Blackburn
https://www.google.com.au/maps/@-37.820 ... 312!8i6656
Looks like we have a maintainer hard at work here, attempting to see if the lights are visible to traffic with the sun directly behind them.
Well,
8 inch LEDs too!SirKrunch wrote:Looks like we have a maintainer hard at work here, attempting to see if the lights are visible to traffic with the sun directly behind them.
Active crossing in Leetonia, Ohio.
https://www.google.com/maps/@40.8753458 ... 6656?hl=en
This crossing has 8'' and 12'' GRS Lex-C lights!
https://www.google.com/maps/@40.8987954 ... 6656?hl=en
https://www.google.com/maps/@40.8987506 ... 6656?hl=en
https://www.google.com/maps/@40.8987288 ... 6656?hl=en
This is just weird.
https://www.google.com/maps/@40.8953993 ... 6656?hl=en
This is just weird.
Also looks like some grade replacement was going on there as well.ToledoRailfan wrote:Active crossing in Leetonia, Ohio.
Nothing wrong with some extra warning is there?ToledoRailfan wrote:This is just weird.
- TrickyMario7654
Ok, someone clearly didn't care about their job...
In case you missed it...
I didn't even know it was there until I saw it active in the Streetview!
Also, this looks to be a wooden wishbone gate!
