Google Maps Scavenger Hunt
- TrickyMario7654
Looks like Google Streetview caught Marshall Street, Ivanhoe active.
https://www.google.com.au/maps/@-37.767 ... 312!8i6656
8" LEDs in Evansville, IN!
https://www.google.com/maps/@37.9812179 ... 312!8i6656
https://www.google.com/maps/@37.9888549 ... 312!8i6656
Inverted 2 Tracks sign:
https://www.google.com/maps/@37.9806423 ... 312!8i6656
- ToledoRailfan
Here is a crossing without any form of signage with the exception of advance warning signs!
https://www.google.com/maps/@40.1489712 ... 6656?hl=en
https://www.google.com/maps/@40.1488146 ... 6656?hl=en
https://www.google.com/maps/@40.1492314 ... 6656?hl=en
https://www.google.com/maps/@40.1486174 ... 6656?hl=en
It appears that operations over this crossing are used with a track mobile so maybe that could be a reason or a contributing reason?
https://www.google.com/maps/@40.1489102 ... 6656?hl=en
Classic signal!
https://www.google.com/maps/@40.1828779 ... 6656?hl=en
https://www.google.com/maps/@40.1826981 ... 6656?hl=en
More classic signals!
https://www.google.com/maps/@40.8585478 ... 6656?hl=en
https://www.google.com/maps/@40.858248, ... 6656?hl=en
Interesting cab signal setup.
https://www.google.com/maps/@40.858351, ... 6656?hl=en
https://www.google.com/maps/@40.8580769 ... 6656?hl=en
https://www.google.com/maps/@40.8582686 ... 6656?hl=en
Two-piece crossbuck!
https://www.google.com/maps/@40.8581619 ... 6656?hl=en
FRA violation?
https://www.google.com/maps/@44.6253411 ... 6656?hl=en
https://www.google.com/maps/@44.6252388 ... 6656?hl=en
Interesting.....
https://www.google.com/maps/@44.6642853 ... 6656?hl=en
Kind of an interesting setup.
https://www.google.com/maps/@44.7977152 ... 6656?hl=en
https://www.google.com/maps/@44.7976747 ... 6656?hl=en
Here is one of those signals that has lights on the top of the signal (we'll have to thing of something to call signals that at like that), this setup is due to a hill right next to the crossing. For some reason I've always been a fan of signals like this one.
https://www.google.com/maps/@44.9212666 ... 6656?hl=en
https://www.google.com/maps/@44.9211532 ... 6656?hl=en
It appears that this classic cantilever signal has been refurbished (for lack of a better term) and it also has new lights!
https://www.google.com/maps/@45.0728513 ... 6656?hl=en
Classic signal!
FRA violation?
Interesting.....
I'll guess and say that this line is out of service.ToledoRailfan wrote:Here is a crossing without any form of signage with the exception of advance warning signs!
It appears that operations over this crossing are used with a track mobile so maybe that could be a reason or a contributing reason?![]()
Very much so! However, those stop signs may no longer be there, because that does look like a very new installation at the time GSV went on by.ToledoRailfan wrote:FRA violation?
- ToledoRailfan
I highly doubt that the line is abandon, the lights at the facility are on and I can't image they would just leave those cars and that track mobile behind.ZachL wrote:I'll guess and say that this line is out of service.ToledoRailfan wrote:Here is a crossing without any form of signage with the exception of advance warning signs!
That would make sense, that is probably why those papers are there.ZachL wrote:Very much so! However, those stop signs may no longer be there, because that does look like a very new installation at the time GSV went on by.ToledoRailfan wrote:FRA violation?
Just because a rail line goes abandoned doesn't mean the business has to go too. They could be using different means of transportation now, such as semi trucks.ToledoRailfan wrote:I highly doubt that the line is abandon, the lights at the facility are on and I can't image they would just leave those cars and that track mobile behind.ZachL wrote:I'll guess and say that this line is out of service.ToledoRailfan wrote:Here is a crossing without any form of signage with the exception of advance warning signs!
I think it just isn't marked due to being an industrial spur.ZachL wrote:Just because a rail line goes abandoned doesn't mean the business has to go too. They could be using different means of transportation now, such as semi trucks.ToledoRailfan wrote:I highly doubt that the line is abandon, the lights at the facility are on and I can't image they would just leave those cars and that track mobile behind.ZachL wrote:I'll guess and say that this line is out of service.ToledoRailfan wrote:Here is a crossing without any form of signage with the exception of advance warning signs!
- ToledoRailfan
Probably true, especially because it appears that a track mobile does most if not all of the operates over the crossing, I assume that it would be flagged. I wonder if this is an FRA violation?freebrickproductions wrote:I think it just isn't marked due to being an industrial spur.ZachL wrote:Just because a rail line goes abandoned doesn't mean the business has to go too. They could be using different means of transportation now, such as semi trucks.ToledoRailfan wrote:I highly doubt that the line is abandon, the lights at the facility are on and I can't image they would just leave those cars and that track mobile behind.ZachL wrote:I'll guess and say that this line is out of service.ToledoRailfan wrote:Here is a crossing without any form of signage with the exception of advance warning signs!
Flagging may actually protect the crossing from being a violation, but I'm not so sure on that.ToledoRailfan wrote:Probably true, especially because it appears that a track mobile does most if not all of the operates over the crossing, I assume that it would be flagged. I wonder if this is an FRA violation?
- ToledoRailfan
Active crossing in Greentown, Indiana. I think it is maulfunctioning.
https://www.google.com/maps/@40.499989, ... 1664?hl=en
https://www.google.com/maps/@40.4998003 ... 1664?hl=en
Classic signals!
https://www.google.com/maps/@40.4925843 ... 6656?hl=en
https://www.google.com/maps/@40.4925864 ... 6656?hl=en
https://www.google.com/maps/@40.4924128 ... 6656?hl=en
https://www.google.com/maps/@40.4800062 ... 1664?hl=en
https://www.google.com/maps/@40.4797643 ... 1664?hl=en
https://www.google.com/maps/@40.4800396 ... 1664?hl=en
https://www.google.com/maps/@40.479829, ... 1664?hl=en
"RAILROAD ⅁NISSOᴚƆ"
https://www.google.com/maps/@40.4990429 ... 6656?hl=en
Classic signals!
"RAILROAD ⅁NISSOᴚƆ"
