WRRS light heads with mounting elbows and mounting base
This part is for people who are looking for particular crossing signal parts or complete signals themselves. Do not put wayside signal parts in this forum.
jd318mike
Post by jd318mike »
Ok trying to sell or finish this set of lights, does anybody have a pair of matching WRRS light heads, with mounting elbows, and a base casting so I can properly mount my flashers. The pole is almost 5", I eyeballed with with the tape measure, was just over 4.75 in dia. While this whole set up weighs a ton, it is neat looking with the cast iron cross bucks. Thanks Mike
Due to economic conditions, the light at the end of the tunnel has been removed.
jd318mike
Re: WRRS light heads with mounting elbows and mounting base
Post by jd318mike »
This set up is all original other than missing the second pair of lights and arms. I used to have one of the spring board mounted flasher relays years ago with the glass bottom. I have seen the plug in style as well. Not as nice as the adjustable type, but sometimes it could be better than nothing. Mike
