Some flat sounding bells
Re: Some flat sounding bells
Here's a pretty bad sounding Safetran mechanical bell:
A rather flat Safetran mechanical bell can be heard at a few points in this video:
Some pretty flat WABCO teardrops over in Italy.
Last edited by NathanFromEngland on Wed Jun 06, 2018 4:19 pm, edited 1 time in total.
check your URL!NathanFromEngland wrote:Some pretty flat WABCO teardrops over in Italy.
Looks like this WCH bell is having a issue between its level of speed and the gong itself.
An early CSX signal there as well.NathanFromEngland wrote:Looks like this WCH bell is having a issue between its level of speed and the gong itself.
Sounds like the "ding rate" significantly increased before the bell shut off.
It appears to be due to the gate mechs as the other bell does the same thing. If you skip to 2:20 in the video, the bell is ringing rather fast before the gates start to lower.ToledoRailfan wrote:Sounds like the "ding rate" significantly increased before the bell shut off.
Very scary sounding General Signals E-bell
One of these mechanical bells at this Dutch crossing is extremely flat.
Unrelated, but it appears this EBA E-bell has died, despite replacing another mechanical bell four years prior.
