Google Street View
Re: Google Street View
Post by ZachL »
dan the ca railfan wrote:and the one in fresno only the sign is original
https://www.google.com/maps/@36.7068925 ... authuser=0
that's the current logo.........
NathanFromEngland
Post by NathanFromEngland »
NathanFromEngland
Post by ZachL »
NathanFromEngland wrote:Why park a trailer here?
https://www.google.co.uk/maps/@28.03828 ... 312!8i6656
Why not?
NathanFromEngland
Why not?
Well, it really is an odd place to park it.
(Also, if you go back a few months, it's still sitting there.)
Post by ZachL »
Why not?
Turn the camera 180...it's Publix headquarters
NathanFromEngland
NathanFromEngland
...This is probably the most confusing signal setup i've ever seen.
https://www.google.co.uk/maps/@42.24122 ... 312!8i6656
dan the ca railfan
Post by dan the ca railfan »
NathanFromEngland wrote:...This is probably the most confusing signal setup i've ever seen.
okay now that is confusing having five light heads instead of three.
plus why is the green light in the middle.
NathanFromEngland
The signal is vertical, so the green goes in the middle, while the arrows go to the bottom, if the signal was horizontal, then the arrows would go to the 3rd and 4th section while the green itself goes to the 5th, here is an example of one in Tampa, Florida, this is under an overpass, so the signal is facing horizontally so drivers can see the signal property. This would avoid confusion with drivers in the straight lane becoming unsure on whether the signal is telling them to turn left.
https://www.google.co.uk/maps/@28.02264 ... 312!8i6656
Also, to answer your question on why there are five light heads (Aspects) that is because it is in a turning lane, so if they are to get a green arrow then they have the right of way, if the light is green but there is no arrow illuminated then you have to yield to other traffic to proceed safely, these are similar to your doghouse signals and your four aspect protected signals.
