that's the current logo.........dan the ca railfan wrote:and the one in fresno only the sign is original
https://www.google.com/maps/@36.7068925 ... authuser=0
Google Street View
- ZachL
Re: Google Street View
Ummmm...
https://www.google.co.uk/maps/@53.79783 ... 312!8i6656
You're going in the same direction!
https://www.google.co.uk/maps/@53.79691 ... 312!8i6656
Why park a trailer here?
https://www.google.co.uk/maps/@28.03828 ... 312!8i6656
Why not?NathanFromEngland wrote:Why park a trailer here?
Well, it really is an odd place to park it.ZachL wrote:Why not?NathanFromEngland wrote:Why park a trailer here?
(Also, if you go back a few months, it's still sitting there.)
Turn the camera 180...it's Publix headquartersNathanFromEngland wrote:Well, it really is an odd place to park it.ZachL wrote:Why not?NathanFromEngland wrote:Why park a trailer here?
A pretty nice mural, (If you have watched American Reunion you should understand this)
https://www.google.co.uk/maps/@33.79478 ... 312!8i6656
Also some old ICC pedestrian signals.
https://www.google.co.uk/maps/@33.79484 ... 312!8i6656
https://www.google.co.uk/maps/@33.79476 ... 312!8i6656
...This is probably the most confusing signal setup i've ever seen.
https://www.google.co.uk/maps/@42.24122 ... 312!8i6656
- dan the ca railfan
okay now that is confusing having five light heads instead of three.NathanFromEngland wrote:...This is probably the most confusing signal setup i've ever seen.
plus why is the green light in the middle.
very lucky to live two-three blocks away from three teardrop bells. one of which i see at least once a week!
The signal is vertical, so the green goes in the middle, while the arrows go to the bottom, if the signal was horizontal, then the arrows would go to the 3rd and 4th section while the green itself goes to the 5th, here is an example of one in Tampa, Florida, this is under an overpass, so the signal is facing horizontally so drivers can see the signal property. This would avoid confusion with drivers in the straight lane becoming unsure on whether the signal is telling them to turn left.dan the ca railfan wrote:okay now that is confusing having five light heads instead of three.NathanFromEngland wrote:...This is probably the most confusing signal setup i've ever seen.
https://www.google.co.uk/maps/@28.02264 ... 312!8i6656
Also, to answer your question on why there are five light heads (Aspects) that is because it is in a turning lane, so if they are to get a green arrow then they have the right of way, if the light is green but there is no arrow illuminated then you have to yield to other traffic to proceed safely, these are similar to your doghouse signals and your four aspect protected signals.
