A few updates from the ATN
Talk about signal news here, including upgrades, downgrades, crossings out of service, abandoned, and so on here.
Went out and chased the ATN yesterday, so I've got a couple of changes to report.
The first update is that at Sanie Road, the WCH bell on the mast signal has been replaced with a GS Type 3 e-bell, and it appears that they at least attempted to touch-up the paint on the lights on that signal. It also turns out that the crossing is in Margaret, AL, not Odenville like I had thought (so I'll have to correct that on the server later).
The second change worth noting is that at 41st Street #1 in Birmingham, the WCH rear lights on the bell-less signal were finally corrected to face the road, though I didn't get any pictures or videos showing this change.
Re: A few updates from the ATN
Saw that Google had finally gotten some new imagery in the Gadsden area, so I was checking out some of the crossings to see if there were any changes.
First off, the Safetran gate mech at I-59 #1 has apparently been replaced with a WCH gate mech, as of December of 2018:
https://www.google.com/maps/@34.0190965 ... 384!8i8192
Also, over in Attalla, AL 77 #2 turns out to have an MI 8 inch light on the bell-less signal! I had thought that this was all WRRS, but I guess not.
https://www.google.com/maps/@34.0338135 ... 384!8i8192
The reason I know it wasn't a replacement is that looking at older imagery, you can just barely make out the MI logo when Google went by in 2014:
https://www.google.com/maps/@34.0338117 ... 312!8i6656
If it weren't for the fact that this branch is out of service, this would most likely be the last MI 8 inch light left in service in the entire state (not aware of any elsewhere personally, not even on the CSX Dothan Sub!)!
Also, I've known about this update for a while, but have yet to document:
The RSI signal at AL 77#1 has had one of the lights replaced with what appears to be a Harmon 12x24 inch light with either an RSI or Patco LED:
https://www.google.com/maps/@34.0432103 ... 384!8i8192
At Henderson Street up in Boaz, the e-bell on the mast signal appears to have been replaced:
https://www.google.com/maps/@34.2201698 ... 384!8i8192
