Bell Sequence Change in Railroad Crossings
jff1999
Post by jff1999 »
Any railroad crossings you have been to have the bell sequence changed. For example, I have been to a crossing in Pensacola, Florida that has the bell sequence changed from bells ring till gates lower to bells ring till gates rise. I am surprised about what CSX did.
February 2019:
November 2019:
Last edited by freebrickproductions on Thu Oct 29, 2020 3:55 pm, edited 1 time in total.
Reason: fixing embeds, please use the YouTubeShort code for shortened YouTube URLs in the future, please.
pluey200
Re: Bell Sequence Change in Railroad Crossings
Post by pluey200 »
Speaking of this, what would a signal maintainer have to do to change the bell sequence on a signal?
railrdc rossng
AndyWS
Post by AndyWS »
I remember this crossing the bell rang only until the gates lowered the first time I shot a train there, shortly thereafter it was changed to have the bell ring all the way from activation to shutdown.
jff1999
Post by jff1999 »
AndyWS wrote: Tue Dec 08, 2020 10:33 pm I remember this crossing the bell rang only until the gates lowered the first time I shot a train there, shortly thereafter it was changed to have the bell ring all the way from activation to shutdown.
Wow!!! That was interesting!
KCMO Railfan
Post by KCMO Railfan »
I remember when the crossings on the Sedalia Sub in Independence had their bells rang from startup until the gates lower, and back again as the gates raise as that is what the MoPac had for their bell sequence. It wasn't around the 2010s when UP began to retrofit all of their lights to electro-techs, along with replacing all of the gate lights to leds from incandescent. UP also changed the bell sequences for all of the crossings in my area, but some had their bell sequences changed again to the MoPac one due to residential areas. Though, most of the crossings now have the current UP sequence except for Vermont Ave, Scott Ave #1, and Cottage St #2 (though I've seen older vids of that crossing when the bells rang the entire time. Don't know why UP changed that bell sequence for).
Last edited by KCMO Railfan on Wed Aug 31, 2022 10:47 pm, edited 2 times in total.
Apparently Redmill Saragossa Road in Saragossa, AL, has had the bell sequence changed to have the bells ring as the gates rise, from having them shut off when the gates had lowered.
