Tracks out of service
Re: Tracks out of service
freebrickproductions wrote:
It seems that the paint of 12x20 inch lights does better than the paint on 8 inch lights.
Just a thought... but I would assume the 12X20 lights are probably replacement lights and are quite a bit newer than the 8 inch lights.
I know around here cantilever lights where the first ones that started changing over to 12 inch lights back in the 80's... mast lights usually stayed at 8 inches for awhile longer. The same thing happened when LED's came into the RR market... they started replacing cantilever lights with them primarily at first. I assume that was due to the LED's lasting longer and meaning less maintenance required and less danger for the maintainer needing to work out on the cantilever.
Probably. I know that L&N installed 12 inch lights on the overhead part of a cantilever with 8 inch lights on the masts for a while.
I also found this a little bit farther down the line:
https://www.google.com/maps?q=3rd+Avenu ... ,5.26&z=21
https://www.google.com/maps?q=3rd+Avenu ... -3.22&z=21
Abandoned Railroad Bridge by freebrickproductions, on Flickr
Unfortunately, 15th Avenue was repaved so there is nothing left of the abandoned crossing there except for the old ROW. :Awww:
I hope someone rescues (or has rescued) those mini bells there
