Weird crossbuck
pluey200
Weird crossbuck
railrdc rossng
- ToledoRailfan
Re: Weird crossbuck
Nice find! That is defiantly a very odd crossbuck.pluey200 wrote:Ive never seen anything like this...
https://www.google.com/maps/@33.3308645 ... 312!8i6656
- ToledoRailfan
Re: Weird crossbuck
I followed the line and I came across this crossing that has the same type of crossbucks!
https://www.google.com/maps/@33.197454, ... 312!8i6656
https://www.google.com/maps/@33.1973624 ... 312!8i6656
The neighboring crossing has normal crossbucks but it does have 8'' lights.
https://www.google.com/maps/@33.1954674 ... 312!8i6656
https://www.google.com/maps/@33.1956109 ... 312!8i6656
I followed the line some more and found this!
And this is the other crossbuck!
Kind of odd having the crossbuck not on the very top of the post. Nothing much, I just thought it looked kind of odd.
https://www.google.com/maps/@33.0767671 ... 312!8i6656
Kind of an odd place to put the "tracks" signs.
https://www.google.com/maps/@33.0741392 ... 312!8i6656
https://www.google.com/maps/@33.0739948 ... 312!8i6656
Re: Weird crossbuck
This is a very famous rail line, having contained the one and only Billups Neon Crossing Signal.
Re: Weird crossbuck
Grenada Railway, which runs that former IC line looked like they were going to try to abandon a lot of that trackage originally... now it seems as though they are using more for car storage. I wonder if they found some new business or were able to get someone to come back online again. Check out this crossing that was OOS and crossbucks removed in 2014. Two years later, the gates were not put back on the signals, but crossbucks were, and you can see a lot of cars being stored.
And speaking of the Stop - Death - Stop crossing...
Ugh, that font makes my head hurt!
Well,
Re: Weird crossbuck
That's probably because the signals don't even operate anymore. The relay case was removed between 2014 and 2016!SirKrunch wrote:Grenada Railway, which runs that former IC line looked like they were going to try to abandon a lot of that trackage originally... now it seems as though they are using more for car storage. I wonder if they found some new business or were able to get someone to come back online again. Check out this crossing that was OOS and crossbucks removed in 2014. Two years later, the gates were not put back on the signals, but crossbucks were, and you can see a lot of cars being stored.
https://www.google.com/maps/@33.6315231 ... 312!8i6656
https://www.google.com/maps/@33.6315377 ... 312!8i6656
Must've reactivated that stretch of track for car storage.
Re: Weird crossbuck
freebrickproductions wrote:That's probably because the signals don't even operate anymore. The relay case was removed between 2014 and 2016!SirKrunch wrote:Grenada Railway, which runs that former IC line looked like they were going to try to abandon a lot of that trackage originally... now it seems as though they are using more for car storage. I wonder if they found some new business or were able to get someone to come back online again. Check out this crossing that was OOS and crossbucks removed in 2014. Two years later, the gates were not put back on the signals, but crossbucks were, and you can see a lot of cars being stored.
It's too bad there isn't a way to identify when the satellite view photos were updated. It also looks like it's possible they reopened the line over to Coffeeville for car storage also... but to do so they would have had to have uncovered some crossings that were paved over in the 2014 streetview images.
https://www.google.com/maps/@33.9570179 ... a=!3m1!1e3
Well,
Re: Weird crossbuck
Satellite was taken on 3-21-16 according to Google Earth.SirKrunch wrote:freebrickproductions wrote:That's probably because the signals don't even operate anymore. The relay case was removed between 2014 and 2016!SirKrunch wrote:Grenada Railway, which runs that former IC line looked like they were going to try to abandon a lot of that trackage originally... now it seems as though they are using more for car storage. I wonder if they found some new business or were able to get someone to come back online again. Check out this crossing that was OOS and crossbucks removed in 2014. Two years later, the gates were not put back on the signals, but crossbucks were, and you can see a lot of cars being stored.
Re: Weird crossbuck
I'll have to ask...is that even legal to have standing signals that do not operate on a non-OOS line?freebrickproductions wrote:That's probably because the signals don't even operate anymore. The relay case was removed between 2014 and 2016!SirKrunch wrote:Grenada Railway, which runs that former IC line looked like they were going to try to abandon a lot of that trackage originally... now it seems as though they are using more for car storage. I wonder if they found some new business or were able to get someone to come back online again. Check out this crossing that was OOS and crossbucks removed in 2014. Two years later, the gates were not put back on the signals, but crossbucks were, and you can see a lot of cars being stored.
Re: Weird crossbuck
Yes, but something has to be done to show that they do not work (such as having the lights bagged and/or turned away from traffic), IIRC. Otherwise, I think the crew may have to flag the crossing.ZachL wrote:I'll have to ask...is that even legal to have standing signals that do not operate on a non-OOS line?freebrickproductions wrote:That's probably because the signals don't even operate anymore. The relay case was removed between 2014 and 2016!SirKrunch wrote:Grenada Railway, which runs that former IC line looked like they were going to try to abandon a lot of that trackage originally... now it seems as though they are using more for car storage. I wonder if they found some new business or were able to get someone to come back online again. Check out this crossing that was OOS and crossbucks removed in 2014. Two years later, the gates were not put back on the signals, but crossbucks were, and you can see a lot of cars being stored.
Must've reactivated that stretch of track for car storage.![]()
